Elmer integration as a solver
Re: Elmer integration as a solver
There is some development of integrating Elmer into Salome going on which for sure we can benefit from.
It looks like that Rainer Jacob already wrote some code to nicely supply/extract all possible solver input setting out of the .edf (xml -files) files which are usually used by ElmerGUI.
The corresponding discussion can be found here...
http://elmerfem.org/forum/viewtopic.php ... a9f1756e5b
while the project can be found here
https://github.com/physici/ElmerSalomeM ... lmerSalome
BR,
HoWil
BR,
HoWil
A bit offtopic. Is there an Elmer package for Debian Jessie available?
I personally use the the official Ubuntu ppa *) thats why I had to search with this results:
There is a relatively old version 7.0 in the experimental branch please see...
https://packages.debian.org/experimental/elmer
For just testing the solver it should be OK but you still have to compile the ElmerGUI if you want to use it too.
For sure there is also the possibility to compile all parts of Elmer see... http://www.elmerfem.org/elmerwiki/index ... stallation
In the official ppa repo is the several days old, the latest version is 8.2-201611251631
https://launchpad.net/~elmer-csc-ubuntu ... er-csc-ppa
@HoWil:
I'm gone try to compile ElmerFEM. I do not know anything about the Elmer languarge to define everything. Would it be possible to make an Elmerfile of the FreeCAD 3D FEM Cantilver Example and post it here. It is easier to test a new FEM with an well know example.
Bernd
Bernd
Hi Bernd,
Attached you find a .zip file with the complete data regarding a Calculix-Elmer comparison which is discussed subsequently.
If you have a running Elmer and want to recompute the Elmer-project just open it with 'File->Load Project', navigate into the folder called 'mesh_with_BC_from_FC-FEM' and press 'Open'.
A short step by step instruction how to rebuild the attached model in FreeCAD, Elmer and Paraview (using 0.17 from ppa and elmer from the official ppa) is given here:
The needed Elmer-Solver input file case.sif where all necessary definitions are listed looks like:
Note that boundary conditions can also be targeted by names from the .unv when simply accessing them by script and not using ElmerGUI.
In FreeCAD:
* Open the standard 3D-FEM example on the start page under 'Example projects' called 'Load an FEM 3D example analysis.
* Select the mesh object called 'Box_Mesh' and delete it. The original Mesh was created with the integrated Netgen-Mesher (and has be recomputed with GMSH).
* Selet the object called 'Cube' and use 'FEM->FEM mesh from shape with GMSH' to generate a new mesh object.
* Select the new mesh object called 'Box_Mesh' and export it via 'File->Export' as 'mesh_with_BC_from_FC-FEM.unv'.
* Execute ElmerGrid in the folder where the exported .unv file is located with 'ElmerGrid 8 2 mesh_with_BC_from_FC-FEM.unv -autoclean'. This transvers the mesh including the boundary conditions stored in the .unv file into several Elmer-mesh files in an identically named folder.
In ElmerGUI:
* Open the transfered mesh with 'File->Load mesh' by simply navigating into the prior generated folder called as the .unv file. The Mesh is now visible.
* In 'Model->Setup->Simulation->Free_text' insert 'Coordinate scaling = 1'.
* 'Model->Equation->Add' and select in the column 'Linear elasticity' 'Acitve->on' and 'Apply to body-> Body1'. Select 'Edit Solver Settings' for in the current tab and there insert in the 'Solver specific options' in the 'Free text input' the string:'Element=p:2'. Than press 'Apply'.
Select in the 'Result Output' column the 'Active' field.
Select 'Edit Solver Settings' for in the current tab and there insert in the 'Solver specific options' in the select in the 'General' tab under 'Execute solver' the point 'After simulation'.
Press 'Apply' and 'OK'.
* 'Model->Material-Add' and select 'Apply to body-> Body1' and select the 'Material library' -> Select 'Steel (alloy -generic)'. Adopt 'Youngs modulus' to '210.0e9' and 'Poisson ratio' to '0.3'.
* Under 'Model->Boundary condition->Add' in column 'Linear elasticity' set 'Displacement 1' and 'Displacement 2' and 'Displacement 3' to 0. Set 'Name:' to 'BoundaryConditionFixed'. Press 'OK'
* Under 'Model->Boundary condition->Add' in column 'Linear elasticity' set 'Force 2' to 9000000. Set 'Name:' to 'BoundaryConditionForce'. Press 'OK'
* Set 'Model->Set boundary properties' and select left boundary with a double-click. Choose 'BoundaryConditionFixed' from pull down-menu. Click 'Add'.
* Set 'Model->Set boundary properties' and select left boundary with a double-click. Choose 'BoundaryConditionForce' from pull down-menu. Click 'Add'.
* 'File->Save'
* 'File->Save Project'
* 'Sif->Generate'
* 'Run->Start solver'
* After the computation has finished: 'Run->Start paraview'.
In Paraview:
Select the 'Properties' window press 'Apply' and select in the subgroup for 'Coloring' 'displacement' instead of 'Solid Color'.
Header
CHECK KEYWORDS Warn
Mesh DB "." "."
Include Path ""
Results Directory ""
End
Simulation
Max Output Level = 5
Coordinate System = Cartesian
Coordinate Mapping(3) = 1 2 3
Simulation Type = Steady state
Steady State Max Iterations = 1
Output Intervals = 1
Timestepping Method = BDF
BDF Order = 1
Solver Input File = case.sif
Post File = case.vtu
Coordinate scaling = 0.001
End
Constants
Gravity(4) = 0 -1 0 9.82
Stefan Boltzmann = 5.67e-08
Permittivity of Vacuum = 8.8542e-12
Boltzmann Constant = 1.3807e-23
Unit Charge = 1.602e-19
End
Body 1
Target Bodies(1) = 1
Name = "Body Property 1"
Equation = 1
Material = 1
End
Solver 2
Equation = Linear elasticity
Element=p:2
Variable = -dofs 3 Displacement
Procedure = "StressSolve" "StressSolver"
Exec Solver = Always
Stabilize = True
Bubbles = False
Lumped Mass Matrix = False
Optimize Bandwidth = True
Steady State Convergence Tolerance = 1.0e-5
Nonlinear System Convergence Tolerance = 1.0e-7
Nonlinear System Max Iterations = 20
Nonlinear System Newton After Iterations = 3
Nonlinear System Newton After Tolerance = 1.0e-3
Nonlinear System Relaxation Factor = 1
Linear System Solver = Iterative
Linear System Iterative Method = BiCGStab
Linear System Max Iterations = 500
Linear System Convergence Tolerance = 1.0e-10
BiCGstabl polynomial degree = 2
Linear System Preconditioning = Diagonal
Linear System ILUT Tolerance = 1.0e-3
Linear System Abort Not Converged = False
Linear System Residual Output = 1
Linear System Precondition Recompute = 1
End
Solver 1
Equation = Result Output
Output Format = Vtu
Procedure = "ResultOutputSolve" "ResultOutputSolver"
Output File Name = case
Exec Solver = After Simulation
End
Equation 1
Name = "Equation 1"
Active Solvers(2) = 2 1
End
Material 1
Name = "Steel (alloy - generic)"
Heat expansion Coefficient = 12.0e-6
Electric Conductivity = 1.367e6
Heat Conductivity = 37.2
Sound speed = 5100.0
Heat Capacity = 976.0
Mesh Poisson ratio = 0.285
Density = 7850.0
Poisson ratio = 0.3
Youngs modulus = 210.0e9
End
Boundary Condition 1
Target Boundaries(1) = 1
Name = "BoundaryConditionFixed"
Displacement 3 = 0
Displacement 2 = 0
Displacement 1 = 0
End
Boundary Condition 2
Target Boundaries(1) = 2
Name = "BoundaryConditionForce"
Force 2 = 9000000
End
- Comparison Calculix_Elmer.zip
- (191.32 KiB) Downloaded 58 times
There is also a short presentation about the structure of .sif files... http://www.nic.funet.fi/pub/sci/physics ... 4April.pdf
In the case that one wants now to reuse the given mechanical simulation model but wants to switch the boundaries, you would have to do the following steps:
* generate a new mesh as .unv with the new faces grouped
* translate it with ElmerGrid and copy the Elmer-Mesh-files into the project folder
* Check if the defined 'Target Boundaries' do still match, see e.g. the prior boundary condition for boundary nr. 2:
compiled the elmer solver and tried to run your example at the command line. Seams I'm missing something essential ...
http://www.elmerfem.org/forum/viewtopic ... 8dc710fcd6
How about just running ElmerSolver instead of its mpi counterpart?
I do not have a binary without mpi. Compiling without mpi fails. But this seams not to be the culprit.HoWil wrote:How about just running ElmerSolver instead of its mpi counterpart?
the elemer solver says the example file has no mesh ?!? see http://www.elmerfem.org/forum/viewtopic ... 124#p15920
