self weight
Re: self weight
Looks like the pull request is being built: https://travis-ci.org/FreeCAD/FreeCAD/builds/146352689
Also shows up in github (checks section): https://github.com/FreeCAD/FreeCAD/pull/225
Re: self weight
travis failed, but my local build is OK
Re: self weight
Tech Draw fails ... ?!
Might be because of this commit https://github.com/berndhahnebach/FreeC ... eb04c6a48a ?!?
On my local machine it builts like a sharm too.
Re: self weight
Could be that one. I saw an error related to VTK in the build log.
Re: self weight
Bernhard, I think your commit is problematic because VTK is required not only for postprocessing (what the BUILD_FEM_VTK check is for) but also for the SMESH. This is the reason we moved the VTK file include out of the check in the first place. So if someone don't want to build the postprocessing he can't build FEM at all anymore after your change as SMESH won't compile and link correctly.
Re: self weight
I removed the commit. https://github.com/FreeCAD/FreeCAD/pull/225 Travis runs smooth now !ickby wrote:Bernhard, I think your commit is problematic because VTK is required not only for postprocessing (what the BUILD_FEM_VTK check is for) but also for the SMESH. This is the reason we moved the VTK file include out of the check in the first place. So if someone don't want to build the postprocessing he can't build FEM at all anymore after your change as SMESH won't compile and link correctly.
Re: self weight
I have filled wiki page https://www.freecadweb.org/wiki/Fem_Con ... SelfWeight
so if someone has any sugestions, he can edit it or make a note here.
After you create ConstraintSelfWeight object you can modify direction of gravity. For the first view on property toolbar I was not sure if X Y Z means whole acceleration or only direction. Is it possible to make it clear by e.g. changing title in the property toolbar from "Gravity" to "Gravity direction" or something like that?
Re: self weight
Thank you.fandaL wrote:I have filled wiki page https://www.freecadweb.org/wiki/Fem_Con ... SelfWeight
Edited https://www.freecadweb.org/wiki/FEM_Con ... SelfWeight.
See https://forum.freecadweb.org/viewtopic.php?f=21&t=19107
Renato
Re: self weight
added scripting and made it a bit more solver depended ... FEM_ConstraintSelfWeight
@renato:
I may totally destroyed the translation tags
@renato:
