My first freeCAD Tutorial
cnirbhay
Post by cnirbhay »
(https://www.youtube.com/watch?v=wAJe1R5NDGw)
My First FreeCAD Tutorial.
I hope you all like it.
Please like, comment, ask questions, share.
Thank you.
Regards
Nirbhay Chauhan
kuroshivo
Re: My first freeCAD Tutorial
Post by kuroshivo »
Nice! Can you share the FreeCAD file?
jeremy
cnirbhay
Post by cnirbhay »
Yes, sure, Jeremy. Here it is with this reply.
My first model.rar
(982.58 KiB) Downloaded 75 times
kuroshivo
Post by kuroshivo »
See http://bit.ly/2bjJI4R for a similar calculation done online at http://www.caeplex.com/demo
Thanks for sharing your work!
jeremy
cnirbhay
Post by cnirbhay »
kuroshivo wrote:See http://bit.ly/2bjJI4R for a similar calculation done online at http://www.caeplex.com/demo
jeremy
Good work done, Jeremy and you're welcome. :)
easyw-fc
Post by easyw-fc »
cnirbhay wrote:(https://www.youtube.com/watch?v=wAJe1R5NDGw)
Thank you.
Regards
Nirbhay Chauhan
Hi @cnirbhay
thank you very much for your tutorial... I've learn how to use FEM from it! :D
viewtopic.php?f=3&t=17068&p=135475#p135475
Would you mind to make a tutorial also for Temperature FEM analysis?
I was trying to replicate those two examples, but I didn't succeed
simplechip_05_multiple_mat.fcstd
from
viewtopic.php?f=18&t=16749&start=40#p133612
or
simple_chip.fcstd
from
viewtopic.php?f=18&t=16749&start=40#p133620
thank you in advance
Maurice
makkemal
Post by makkemal »
I will try todo the video tutorial thingy on this, somthing new to learn ;)
makkemal
Post by makkemal »
Ok I gave this ago , it took a few tries
https://youtu.be/CGSrqvAZ97M
PCB_example.fcstd
(577.2 KiB) Downloaded 100 times
See if it makes sense
cnirbhay
Post by cnirbhay »
easyw-fc wrote:Hi @cnirbhay
from
or
simple_chip.fcstd
from
Maurice
Yes, sure, Maurice. I'll make your desired tutorial soon after updating my FreeCAD version with thermal attributes, even you can tell me more topics on FreeCAD, I'll make tutorials on that too. :-)
Nirbhay Chauhan
https://cnirbhay.wordpress.com/
easyw-fc
Post by easyw-fc »
makkemal wrote:Ok I gave this ago , it took a few tries
PCB_example.fcstd
Hi @makkemal thank you very much for the 'illuminating' and very useful tutorial! :D
I managed to replicate your analysis using the latest FC 0.17 8318 in win10 64b
1) I just opened your example in FC 0.17 7745
2) I removed all the analysis and create the Mesh
3) I copied the Fusion object and the Meshed into FC 0.17 8318
4) I replicated all the steps as in your tutorial
and that's it! :D
I still get a slightly different colors result, but it seems to be aligned to your simulation and I don't get anymore warning or error messages on Report Window...
I will see if I can replicate it also on a VM with ubuntu and see if the colors will be as in your example...
Thank you again for your support and for your effort in FEM Analysis!
cnirbhay wrote:Yes, sure, Maurice. I'll make your desired tutorial soon after updating my FreeCAD version with thermal attributes, even you can tell me more topics on FreeCAD, I'll make tutorials on that too. :-)
Thanks again for your tutorial, it helps me a lot!
I'll be tuned to this channel!
Maurice
