you will need these packages: https://github.com/FreeCAD/FreeCAD/blob ... is.yml#L62easyw-fc wrote:now I have to see if I can built FC at least in a VM under ubuntu
FEM analysis error on "ThermoMechSteadyState"
Re: FEM analysis error on "ThermoMechSteadyState"
It's really not any harder than ubuntu.easyw-fc wrote:now I have to see if I can built FC at least in a VM under ubuntu
(the way to build in win is a quite more complex to me to be achieved )
What are you holing out?bernd wrote:you will need these packages: https://github.com/FreeCAD/FreeCAD/blob ... is.yml#L62
@easy-fc
Install xenial and use bernd's script
viewtopic.php?f=13&t=18397
Anyway I post a win build in about 6 hours.
"fight the good fight"
Ahh yeah you could use the script too. You will get OCCT 7.0.0 You can get it from my Github: https://gist.github.com/berndhahnebach/ ... 01a94df05fsgrogan wrote:@easy-fc
thx I didn't know about @bernd script...sgrogan wrote: What are you holing out?
@easy-fc
thx for the win build, I will download asaasgrogan wrote: Anyway I post a win build in about 6 hours.
I followed the instruction to create a building environment in win
http://www.freecadweb.org/wiki/?title=CompileOnWindows
but it seems much harder than in linux, and in linux I remember that I already did once
Is there any tricky script to create a building windows environment?
I'm a bit more familiar with msys2 or cygwin but it seems for building FC in win, ms compiler is the right compiler...
Maurice
Win x64 build https://github.com/sgrogan/FreeCAD/rele ... g/0.17-dev
Some version of VS2013 is required at the moment (unless you want to take care of the libs yourself). I read the wiki and it needs some love. If you open a topic in install/compile I'm sure we can walk you thru it.easyw-fc wrote:Is there any tricky script to create a building windows environment?
Hi @sgrogansgrogan wrote:Win x64 build https://github.com/sgrogan/FreeCAD/rele ... g/0.17-dev
I downloaded both 32 & 64 version but I cannot found the new dialog options as in @makkemal screenshot
thx
Maurice
Should be this one https://github.com/sgrogan/FreeCAD/rele ... ild-x64.7z
Updated
The temp constraint has total heat input in Watt (like yesterday)
Convection constraint also now support heat flux in Watt/m^2
https://github.com/makkemal/FreeCAD/tree/HeatFlux_v2
thx a lot @makkemal @KgoaOT for this feature!makkemal wrote:Updated
thx @sgrogan for the building
tested fine on win10 64b
Maurice
+1 for a PRmakkemal wrote:Updated
