Mesh Settings
Re: Mesh Settings
Hi bernd,
I did again play a bit with Part-Design-Next for creating a mesh-region multi-domain mesh. Until now I was unsuccessful in creating such a mesh.
Is it possible for you to select a Part-Design-Next-'Part' (holding several bodies) and do the Boolean Fragments operation automatically?
Re: Mesh Settings
Could you post an simple example file?HoWil wrote: I did again play a bit with Part-Design-Next for creating a mesh-region multi-domain mesh. Until now I was unsuccessful in creating such a mesh.
Re: Mesh Settings
I try to rebuild the same model as before (box in a box) just using Part-Design-Next instead of Part-WB. PDS should be used in my opinion because of its superior creation processes.
The model I posted earlier can be found here:
viewtopic.php?f=18&t=18780&start=30#p148005
What I struggle with is:
* I do not know with which elements I should make the 'Boolean Fragments' operation, with the bodies with the solids in the bodies or with a top-level part-element.
* I noticed that after creation of the mesh at some point the solids and bodies were not found any more. See the output in the command line for the given example .fcstd when trying to remesh or select new materials:
Can't find Origin for "Body"
Can't find Origin for "Body001"
Solid <Solid object at 0x8208370> not found in: <Compound object at 0x27ecc40>
Problem: No element found for: <Solid object at 0x8208370>
Error: shapes for: MechanicalMaterialnot found!
Solid <Solid object at 0x8cea010> not found in: <Compound object at 0x85ba270>
Problem: No element found for: <Solid object at 0x8cea010>
Re: Mesh Settings
I have not had the time to had a look at the PartDesignNext stuff. Will do this at last may be after the merge in master. Did change some code here and there. Would it be possible to test again? Solid selection of material objects work the same way as mesh region objects. Thus it is possible to select solids of Compounds an CompSolids. Old material objects might be broken. just recreate them.
https://github.com/berndhahnebach/FreeC ... meshregion
From my point of view we only need some testing again and an icon for the PullRequest.
Bernd
Bernd
Re: Mesh Settings
I will test it again during the next days using your current MeshRegion status.
I will also ask in the Part-Design-Next corner if there are any plans to "officially" introduce boolean fragments for parts and bodies.
BR Howil
Ps.: hopefully it will not fail due to the missing icon
BR Howil
Re: Mesh Settings
Some test builds: https://github.com/sgrogan/FreeCAD/rele ... g/0.17-devbernd wrote:From my point of view we only need some testing again and an icon for the PullRequest.
@bernd how do I make a FEM meshed cube with a square, triangle, circle on visible faces. Each meshed differently than the default cube. I'm behind on the Boolean fragment stuff. I'm thinking for an icon.
Like here: viewtopic.php?f=3&t=18207&start=10
"fight the good fight"
Re: Mesh Settings
See attaches file, but it did not work. See attached scree. I'll have a look.sgrogan wrote:@bernd how do I make a FEM meshed cube with a square, triangle, circle on visible faces. Each meshed differently than the default cube. I'm behind on the Boolean fragment stuff.
Re: Mesh Settings
I pushed a fix in the regard of multi solid body meshing. But the face by sketch on face of solid with smaller mesh does not yet work. I need to have a closer look.sgrogan wrote:@bernd how do I make a FEM meshed cube with a square, triangle, circle on visible faces. Each meshed differently than the default cube. I'm behind on the Boolean fragment stuff.
How about such an icon?
Re: Mesh Settings
I think this would work. It gets the idea across.bernd wrote:How about such an icon?
Re: Mesh Settings
Found the culprit. It is the compound. But it is something not that easy to fix. One problem are the exported node numbers from FreeCAD. But even if the node numbers are al right GMSH has problems if the shape is a Compound. The Solid or CompSolid has to be extracted from the Compound (BTW all booleans return Compounds: see viewtopic.php?t=16773) Best way to extract the Solid or CompSolid ist to use CompoundFilter from lattice2 workbench. Attached Screen and file ... I had to change the mesh region element size to add the file. Screen is made with 0.2bernd wrote:See attaches file, but it did not work. See attached scree. I'll have a look.sgrogan wrote:@bernd how do I make a FEM meshed cube with a square, triangle, circle on visible faces. Each meshed differently than the default cube. I'm behind on the Boolean fragment stuff.
