Mesh Settings
Re: Mesh Settings
Just a thought, did you try if it works for just point (area, line, point) ?
Re: Mesh Settings
I tried to use PartDesingNext to achieve something similar and did partly fail. I created a sketch on top of a box and tested three different approaches of combining the box with the sketch:bernd wrote:Found the culprit. It is the compound. But it is something not that easy to fix. One problem are the exported node numbers from FreeCAD. But even if the node numbers are al right GMSH has problems if the shape is a Compound. The Solid or CompSolid has to be extracted from the Compound (BTW all booleans return Compounds: see viewtopic.php?t=16773) Best way to extract the Solid or CompSolid ist to use CompoundFilter from lattice2 workbench. Attached Screen and file ... I had to change the mesh region element size to add the file. Screen is made with 0.2bernd wrote:See attaches file, but it did not work. See attached scree. I'll have a look.sgrogan wrote:@bernd how do I make a FEM meshed cube with a square, triangle, circle on visible faces. Each meshed differently than the default cube. I'm behind on the Boolean fragment stuff.
geometry_on_faces4.fcstd
* BooleanFragments of Sketch and box
* BooleanFragments of a Facebinder of the Sketch and box
* XOR of Sketch and box
for all three I get a solid as expected, with a circular face on the top face of the box. But i struggle to mesh this solids with a separate mesh-region setting for the circle (Face7 of boolean-fragments). Instead a finer mesh is created at a vertex of the solid.
Is this related to the problems reported above (wrong numbers of the compound between FC and Gmsh)?
- FC_mesh_faces_v1p0.fcstd
- The FC file unsing a shapebinder.
- (130.47 KiB) Downloaded 46 times
- Screenshot from 2016-12-17 22-22-33.png (212.12 KiB) Viewed 2570 times
- Screenshot from 2016-12-17 22-11-43.png (111.13 KiB) Viewed 2570 times
Re: Mesh Settings
yes, there are problems if a Compound is passed GMSH. Extract the Solid out of the Compound see my last post viewtopic.php?f=18&t=18780&start=40#p149467 for an explanation an how to do this. Attached screen and file:HoWil wrote:Is this related to the problems reported above (wrong numbers of the compound between FC and Gmsh)?
Re: Mesh Settings
the icon added:
I did some changes in the GMSH mesh object too. They all need to be recreated.
added some messages and a pop up in the regard of compounds. From my point of view it is ready to make a PullRequest. Would be cool if some test would be made before I'm gone go for the PR.I did some changes in the GMSH mesh object too. They all need to be recreated.
Re: Mesh Settings
It is not the Compound it is the BooleanFragments Compound. The brep exported from a BooleanFragments Compound could be not the shape the user expects to be. If the CompoundFilter is used on a BooleanFragment and a Compound is made from this GMSH returns the expected result.bernd wrote:yes, there are problems if a Compound is passed GMSH. Extract the Solid out of the Compound see my last post viewtopic.php?f=18&t=18780&start=40#p149467 for an explanation an how to do this.HoWil wrote:Is this related to the problems reported above (wrong numbers of the compound between FC and Gmsh)?
How to proceed? Be careful with passing a BooleanFragments Compound to GMSH mesh object. Use CompoundFilter on top of the BooleanFragment instead. We may should think about integrating the CompoundFileter in FreeCAD. I may have a look at this after merge into master. viewtopic.php?f=8&t=16773&start=10#p144537
attached the file. Try to change the shape to mesh from the mesh object. Use the Compound, the CompoundFilter and the BooleanFragments. See the differnent report errors and the different meshes (The BooldeanFragment returns a not expected mesh)
Re: Mesh Settings
I can't test this yet because I am on the way but I do have a short comment on the selection of inner solids from click or 'mouseover' and highlight the selected items as also discussed over here:
viewtopic.php?f=10&t=19072#p148870
For getting all elements below the cursor one can use:
For highlighting a element one can use for example:
Sorry, I do not have the time to synthetize this a bit more but hope this is helpful.
ps.: You can easily test this with the 'Load a PartDesign example' from the FC-startpage and zoom the model until it fills the complete drawing window (so that the coordinates 0,0 will find a thing in the example above).
listObjects = FreeCADGui.ActiveDocument.ActiveView.getObjectsInfo((int(0),int(0))) # the two zeros are to my knowledge the coordinates in the drawing window, this can be replaces with coordinates from a click
print(listObjects)
FreeCADGui.Selection.addSelection(FreeCAD.ActiveDocument.Pocket002,'Face6')
Re: Mesh Settings
It looks like a png-Icon. A better scalability will be get with a svg-icon. Maybe agryson can help here?bernd wrote:the icon added:
Ulrich
Re: Mesh Settings
I just added the png because an svg is not shown on the forum. See https://github.com/berndhahnebach/FreeC ... region.svg for the real svgulrich1a wrote:It looks like a png-Icon. A better scalability will be get with a svg-icon.bernd wrote:the icon added:
Re: Mesh Settings
compiling again......
@bernd:
Can you please set the standard setting for the mesh region from 2mm to the standard-value 0mm of the overall gmsh-object.
I usually start testing with the 3D-beam example and there is the length of the beam 8000mm resulting in a forced-kill of FC.
EDIT:
I am not sure if there is a better setting for this.... 0mm results in only one element along the complete beam: EDIT2:
0mm results in ....
@bernd:
EDIT:
0mm results in ....
The Part should have a pretty new FEM mesh!
Error : Wrong mesh element size lc = 0 (lcmin = 0, lcmax = 1e+22)
Re: Mesh Settings
The problems do in my test cases only happen when I select for instance a inner face in a 'Fusion' as long as I select only faces on the outside of the resulting body/solid everything works as expected.bernd wrote: How to proceed? Be careful with passing a BooleanFragments Compound to GMSH mesh object. Use CompoundFilter on top of the BooleanFragment instead. We may should think about integrating the CompoundFileter in FreeCAD. I may have a look at this after merge into master. viewtopic.php?f=8&t=16773&start=10#p144537
