In the FEM ther are two times setEdit(...) where i have to edit some Gui.
The case is it shows only the second Gui(Mesh creation).
App.activeDocument().addObject('Fem::FemMeshShapeNetgenObject', 'Fusion_Mesh')
App.activeDocument().ActiveObject.Shape = App.activeDocument().Fusion
Gui.activeDocument().setEdit(App.ActiveDocument.ActiveObject.Name)
MechanicalMaterial.makeMechanicalMaterial('MechanicalMaterial')
App.activeDocument().Analysis.Member = App.activeDocument().Analysis.Member + [App.ActiveDocument.ActiveObject]
I can imagine that this is more ore less FreeCAD broad so if it has moved to some other topic location it is fine
Hole Script
# -*- coding: utf-8 -*-
# Macro Begin: /Users/UserName/Library/Preferences/FreeCAD/Macro/test_rec.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
import FreeCAD
import Part
import _CommandAnalysis
import FemGui
import FemAnalysis
import FemSolverCalculix
import Fem
import _CommandMechanicalMaterial
import MechanicalMaterial
import _CommandMeshNetgenFromShape
import _CommandControlSolver
App.newDocument("Unnamed")
#App.setActiveDocument("Unnamed")
#App.ActiveDocument=App.getDocument("Unnamed")
#Gui.ActiveDocument=Gui.getDocument("Unnamed")
#Gui.activateWorkbench("PartWorkbench")
App.ActiveDocument.addObject("Part::Box","Box")
App.ActiveDocument.ActiveObject.Label = "Cube"
#Gui.SendMsgToActiveView("ViewFit")
FreeCAD.getDocument("Unnamed").getObject("Box").Length = '5 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Length = '50 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Width = '0 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Width = '50 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Height = '0 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Height = '50 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Height = '500 mm'
FreeCAD.getDocument("Unnamed").getObject("Box").Length = '250 mm'
FreeCAD.getDocument("Unnamed").getObject("Box001").Length = '0 mm'
FreeCAD.getDocument("Unnamed").getObject("Box001").Length = '20 mm'
FreeCAD.getDocument("Unnamed").getObject("Box001").Length = '250 mm'
FreeCAD.getDocument("Unnamed").getObject("Box001").Width = '0 mm'
FreeCAD.getDocument("Unnamed").getObject("Box001").Width = '50 mm'
FreeCAD.getDocument("Unnamed").getObject("Box001").Height = '0 mm'
FreeCAD.getDocument("Unnamed").getObject("Box001").Height = '50 mm'
FreeCAD.getDocument("Unnamed").getObject("Box001").Placement = App.Placement(App.Vector(20,0,0),App.Rotation(App.Vector(0,0,1),0))
FreeCAD.getDocument("Unnamed").getObject("Box001").Placement = App.Placement(App.Vector(250,0,0),App.Rotation(App.Vector(0,0,1),0))
App.activeDocument().addObject("Part::Fuse","Fusion")
App.activeDocument().Fusion.Base = App.activeDocument().Box
App.activeDocument().Fusion.Tool = App.activeDocument().Box001
#Gui.activeDocument().hide("Box")
#Gui.activeDocument().hide("Box001")
#Gui.ActiveDocument.Fusion.ShapeColor=Gui.ActiveDocument.Box.ShapeColor
#Gui.ActiveDocument.Fusion.DisplayMode=Gui.ActiveDocument.Box.DisplayMode
#Gui.activateWorkbench("FemWorkbench")
FemAnalysis.makeFemAnalysis('Analysis')
FemGui.setActiveAnalysis(App.activeDocument().ActiveObject)
FemSolverCalculix.makeFemSolverCalculix('CalculiX')
FemGui.getActiveAnalysis().Member = FemGui.getActiveAnalysis().Member + [App.activeDocument().ActiveObject]
App.activeDocument().addObject("Fem::ConstraintFixed","FemConstraintFixed")
App.activeDocument().FemConstraintFixed.Scale = 1
App.activeDocument().Analysis.Member = App.activeDocument().Analysis.Member + [App.activeDocument().FemConstraintFixed]
for amesh in App.activeDocument().Objects:
if "FemConstraintFixed" == amesh.Name:
amesh.ViewObject.Visibility = True
elif "Mesh" in amesh.TypeId:
aparttoshow = amesh.Name.replace("_Mesh","")
for apart in App.activeDocument().Objects:
if aparttoshow == apart.Name:
apart.ViewObject.Visibility = True
amesh.ViewObject.Visibility = False
#Gui.activeDocument().setEdit('FemConstraintFixed')
App.ActiveDocument.FemConstraintFixed.Scale = 6
App.ActiveDocument.FemConstraintFixed.References = [(App.ActiveDocument.Fusion,"Face1")]
#Gui.activeDocument().resetEdit()
App.activeDocument().addObject("Fem::ConstraintForce","FemConstraintForce")
App.activeDocument().FemConstraintForce.Force = 1.0
App.activeDocument().FemConstraintForce.Reversed = False
App.activeDocument().FemConstraintForce.Scale = 1
App.activeDocument().Analysis.Member = App.activeDocument().Analysis.Member + [App.activeDocument().FemConstraintForce]
if "FemConstraintForce" == amesh.Name:
#Gui.activeDocument().setEdit('FemConstraintForce')
App.ActiveDocument.FemConstraintForce.Force = 10000
App.ActiveDocument.FemConstraintForce.Direction = None
App.ActiveDocument.FemConstraintForce.Reversed = False
App.ActiveDocument.FemConstraintForce.Scale = 6
App.ActiveDocument.FemConstraintForce.References = [(App.ActiveDocument.Fusion,"Face10")]
App.activeDocument().addObject("Fem::ConstraintForce","FemConstraintForce001")
App.activeDocument().FemConstraintForce001.Force = 1.0
App.activeDocument().FemConstraintForce001.Reversed = False
App.activeDocument().FemConstraintForce001.Scale = 1
App.activeDocument().Analysis.Member = App.activeDocument().Analysis.Member + [App.activeDocument().FemConstraintForce001]
if "FemConstraintForce001" == amesh.Name:
#Gui.activeDocument().setEdit('FemConstraintForce001')
App.ActiveDocument.FemConstraintForce001.Force = 500
App.ActiveDocument.FemConstraintForce001.Direction = None
App.ActiveDocument.FemConstraintForce001.Reversed = False
App.ActiveDocument.FemConstraintForce001.Scale = 6
App.ActiveDocument.FemConstraintForce001.References = [(App.ActiveDocument.Fusion,"Edge9")]
# Macro End: /Users/UserName/Library/Preferences/FreeCAD/Macro/test_rec.FCMacro +++++++++++++++++++++++++++++++++++++++++++++++++
