When I run the simulation I finally get the following 'error'-message in the Report-View and no results:
FEM: No nodes found in Frd file.
FEM: No result object in active Analysis.
When I run the same model as stationary mech. simulation everything works great which indicates that the mesh is found and the FEM wb works generally. See the output in the Report-view for running the mech. simulation and than the thermomech. one.
Did I miss something or is this a bug?
BR,
HoWil
OS: Ubuntu 16.04.1 LTS
Version: 0.17.9592 (Git)
Build type: None
Hash: c2f2a250549163947592069262ce1cd3328b3669
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
FEM preferences working dir is not set, the solver working directory is used.
Dir '' doesn't exist and cannot be created.
Dir '/tmp' will be used instead.
FemTools.setup_working_dir() --> self.working_dir = /tmp
FemInputWriterCcx --> self.dir_name --> /tmp
FemInputWriterCcx --> self.main_file_name --> Body_Mesh.inp
FemInputWriterCcx --> self.file_name --> /tmp/Body_Mesh.inp
Constraint: FemConstraintFixed --> mesh group: FemConstraintFixed_Nodes
Writing time input file: 0.032568
runCalculix
run CalculiX at: ccx with: /tmp/Body_Mesh
calculixStarted()
PySide.QtCore.QProcess.ProcessState.Running
calculixFinished() 0
PySide.QtCore.QProcess.ProcessState.NotRunning
Writing time input file: 0.03444
runCalculix
calculixStarted()
calculixFinished() 255
