the example file can be found heremakkemal wrote:Can you post an updated example the earlier one is giving a number of errors
Test request - 1D flow
Re: Test request - 1D flow
Damn convergence problems ... Do I have the same problem as here ... viewtopic.php?f=18&t=20276&start=10#p156853 Michael does the example run for you ?KgoaOT wrote:the example file can be found heremakkemal wrote:Can you post an updated example the earlier one is giving a number of errors
1DPipe.fcstd
BTW: rebased on master and made it flake8 compatible. Furthermore I would implement the mesh tools for replacing the element name in the mesh tools module See https://github.com/berndhahnebach/FreeC ... fem1dfluid
Test file is working fine
I think broke it but it is working nicely.
I like the fact that you have to account for gravity in the the fluid.
The test not working (it may just be the operator) seen to be the split input file writer ?
It solves if I take that off
makkemal wrote:Test file is working fine
1dtest.fcstd
1dtest2.fcstd
I have just included the "Split input writter implementation"
The branch can be found here: https://github.com/stoflap/FreeCAD/tree/FluidSection
I am not experiencing any divergence problems on my system.bernd wrote:Damn convergence problems ... Do I have the same problem as here ... viewtopic.php?f=18&t=20276&start=10#p156853 Michael does the example run for you ?
OS: Ubuntu 16.04.1 LTS
Version: 0.17.9909 (Git)
Build type: Unknown
Branch: FluidSection
Hash: 9dbb61202ecae63e957692075ea0a11a95124d77
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Regards.
Thanks
Split input writer does not break things anymore.
However I cannot get any example to converge with more than just inlet outlet and single pipe in between
Can you post an example containing all implemented elements please ?
The reason one would want a 1D flow network is it would be very complex to solve with 3D CFD if you have a number of pipe connections etc
Suggestions
1. Change the "add reference" to "add/remove"
If you have a number of pipe sections/bends they will be the same pipe maning thus multiple selection will be useful.
2. Is it possible to have the selected bodies high lite when only highlighting the fluid section in the tree.
Having to open each fluid section individually to check network is tedious
For the rest Great work !
Suggestions
I have attached example with all the possible elements:makkemal wrote: Can you post an example containing all implemented elements please ?
makkemal wrote: Suggestions
I have tried to do this, but it does not work like the other constraints.
What is expected is first for the user to select the shape( edge, vertex, face) and then click add.
But it works the other way around.
The branch is here: https://github.com/stoflap/FreeCAD/tree/FluidSection
Perhaps Bernd can help as I copied the way he implemented the Beam Section and Shell Section
If one can select the object, look for what "References" the object contains and then highlighting should be easy.
Regards
I get the following error in Windows
Work fine in linux
FemTools.setup_working_dir() --> self.working_dir = C:/ccxtmp
File "C:\FreeCAD_compile\Mod\Fem\_TaskPanelFemSolverCalculix.py", line 168, in calculixFinished
fea.load_results()
File "C:\FreeCAD_compile\Mod\Fem\FemToolsCcx.py", line 229, in load_results
self.load_results_ccxfrd()
File "C:\FreeCAD_compile\Mod\Fem\FemToolsCcx.py", line 240, in load_results_ccxfrd
ccxFrdReader.importFrd(frd_result_file, self.analysis, result_name_prefix)
File "C:\FreeCAD_compile\Mod\Fem\ccxFrdReader.py", line 465, in importFrd
m = readResult(filename)
File "C:\FreeCAD_compile\Mod\Fem\ccxFrdReader.py", line 54, in readResult
os.remove("inout_nodes.txt")
WindowsError: [Error 32] The process cannot access the file because it is being used by another process: 'inout_nodes.txt'
The problem is fixed and a few other bugs. The latest branch: https://github.com/stoflap/FreeCAD/tree/FluidSectionmakkemal wrote:I get the following error in Windows
Work fine in linuxCode: Select all
FemTools.setup_working_dir() --> self.working_dir = C:/ccxtmp Traceback (most recent call last): File "C:\FreeCAD_compile\Mod\Fem\_TaskPanelFemSolverCalculix.py", line 168, in calculixFinished fea.load_results() File "C:\FreeCAD_compile\Mod\Fem\FemToolsCcx.py", line 229, in load_results self.load_results_ccxfrd() File "C:\FreeCAD_compile\Mod\Fem\FemToolsCcx.py", line 240, in load_results_ccxfrd ccxFrdReader.importFrd(frd_result_file, self.analysis, result_name_prefix) File "C:\FreeCAD_compile\Mod\Fem\ccxFrdReader.py", line 465, in importFrd m = readResult(filename) File "C:\FreeCAD_compile\Mod\Fem\ccxFrdReader.py", line 54, in readResult os.remove("inout_nodes.txt") WindowsError: [Error 32] The process cannot access the file because it is being used by another process: 'inout_nodes.txt'
Nice Ofenste it is working well in Windows and Linux
You only need a few more fluid section types to support all of them.
I suggest reproducing the following exmaple
http://feacluster.com/CalculiX/ccx_2.11 ... ode13.html
and adding it to the unit tests
+1makkemal wrote:I suggest reproducing the following exmaple
and may be try to rebase on this branch since it will be in master soon, hopfully: https://github.com/berndhahnebach/FreeC ... its/femdev
