Test request - 1D flow
KgoaOT
Post by KgoaOT »
I have done the implementation of 1D flow using FLUID SECTION definition which works similarly to the BEAM SECTION and SHELL SECTION
An example on the CalculiX manual http://feacluster.com/CalculiX/ccx_2.10 ... ode13.html).
I have attached the example file here:
1DPipe.fcstd
(8.16 KiB) Downloaded 74 times
In the example file the is a pipe with an inlet and outlet. The inlet pressure and Inlet flow rate is used to determine the outlet pressure.
Currently the results from the analysis are not read into FreeCAD because 1D flow results are not supported. Furthermore visualization of the results is also another thing that needs consideration.
The branch can be found here: https://github.com/stoflap/FreeCAD/tree/FluidSection
OS: Ubuntu 16.04.1 LTS
Version: 0.17.9700 (Git)
Build type: Unknown
Branch: FluidSection
Hash: 14ae74f4681b231fd44ba0a0032068164ed7bb01
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
regards
kgoaOT
HoWil
Re: Test request - 1D flow
Post by HoWil »
Sounds interesting...
bernd
Post by bernd »
@KgoaOT:
wow cool, would you post an example analysis?
KgoaOT
Post by KgoaOT »
bernd wrote:@KgoaOT:
I have attached the file above 8-)
bernd
Post by bernd »
Damn small screen ... I'm on my smart phone ATM. Sorry ... :oops:
bernd
Post by bernd »
I did a rebase on master, some code formating and fixed z88. All can be found on branch:
https://github.com/berndhahnebach/FreeC ... fem1dfluid
Some result reading should be implemented before we gone merge it into master IMHO. @KgoaOT: Are you gone plan to do this?
KgoaOT
Post by KgoaOT »
bernd wrote: Some result reading should be implemented before we gone merge it into master IMHO. @KgoaOT: Are you gone plan to do this?
Yes I will also look into this.
Regards
KgoaOT
KgoaOT
Post by KgoaOT »
The results for 1D flow are now supported:
as well as in vtk. But in vtk we can only currently view the results in terms of the nodes:
the link to the branch can be found here:
Feedback and comments will be much appreciated.
regards
KgoaOT
bernd
Post by bernd »
KgoaOT wrote:as well as in vtk. But in vtk we can only currently view the results in terms of the nodes:
You only have been using a mesh with 7 nodes. If you would use 100 it would be better or am I wrong?
makkemal
Post by makkemal »
Can you post an updated example the earlier one is giving a number of errors
