Importing Equivalent Plastic Strain
sodelo
Re: Importing Equivalent Plastic Strain
Post by sodelo »
I have not (yet) run your example but is there something strange?
The beam is bended. Maximal stress and strains are on both surfaces (top and bottom). Plasticity is reached at these locations while the core is still elastic.
bernd
Post by bernd »
sodelo wrote:I have not (yet) run your example but is there something strange?
No nothing strange just some finer mesh even inside the body and not only on the surface.
sodelo
Post by sodelo »
With tetrahedra, having a fine enough mesh often means having a hell of a big mesh :?
With hexahedra, 1st they are more accurate and second, you can cheat and get your fine elements only in the direction you are interested in.
bernd
Post by bernd »
sodelo wrote:With tetrahedra, having a fine enough mesh often means having a hell of a big mesh :?
Do you know GMSH? Do you know how to make hex elements in GMSH? I have not been successful with this.
sodelo
Post by sodelo »
I have used it in the past (only for a particular geometry) and got a rather nice hexahadra-based mesh.
I need to find the file and send it to you.
However I remember the geometry has to be defined with the Gmsh tools in that case and all the partitioning as well.
bernd
Post by bernd »
It's in master ...
sodelo
Post by sodelo »
Capture du 2017-02-21 22-42-46.png (367.62 KiB) Viewed 1907 times
Sorry for the strange location of the radio button. This is the first time I use QtDesigner.
TaskPanelShowResult.ui.txt
Change the file extension
(15.34 KiB) Downloaded 222 times
_TaskPanelShowResult.py
(19.72 KiB) Downloaded 74 times
importCcxFrdResults.py
(26.6 KiB) Downloaded 67 times
bernd
Post by bernd »
sodelo wrote:Sorry for the strange location of the radio button. This is the first time I use QtDesigner.
fixed
https://github.com/berndhahnebach/FreeC ... empestrain
https://github.com/berndhahnebach/FreeC ... it/04f7156
will be included in my next PR ...
bernd
Post by bernd »
added Peeq to vtk output too: https://github.com/berndhahnebach/FreeC ... its/femdev
sodelo
Post by sodelo »
:D
