To make the model easier to understand I like to rename the different entities (geometries, boundary conditions, materials) with more explicit names. However it is not taken into account in the input file. Am I doing something wrong?
Version: 0.17.10150 (Git)
Hash: 978978f7dd1814083d7b9c9fc4267dba25f58a80
Python version: 2.7.8
OCC version: 7.0.0
Thanls,
Object Renaming is not taken into account in the Calculix input file
Re: Object Renaming is not taken into account in the Calculix input file
And what about keeping the actual way (use names) and write the label as a comment (for each material, Boundary conditions, ...)? This could be a way to get a much more readable input files with minimum changes.
Mhh no one has had this idea so far. Seams reasonable, because the file is much better readable and special character do not cause problems because it's a comment. We should add it as an option. You could fill in a bug report and assign it to me, or you give it a try your self.sodelo wrote:And what about keeping the actual way (use names) and write the label as a comment (for each material, Boundary conditions, ...)? This could be a way to get a much more readable input files with minimum changes.
Bernd
Simple but efficient!
It would be nice to be able to rename the input file as well.
Sodelo
Sodelo
you can change this yourself here: https://github.com/berndhahnebach/FreeC ... Ccx.py#L61sodelo wrote:It would be nice to be able to rename the input file as well.
OK,I will make a proposal asap.
BR
Sodelo
BR
Sodelo
