For relatively complex simulation (eg non linear with contact), a convergence issues is related to a particular element or node.
Is there a way to highlight (showing where it is located) a node or element by its label?
Thanks,
Getting the location of a specific element or node
Re: Getting the location of a specific element or node
not with gui.
- start FreeCAD, load FEM3Dexample from StartWB
- run code
Watch status line if you move with your mouse over faces, edges, nodes of a FEM mesh
- run code
mesh_obj = App.ActiveDocument.Box_Mesh
mesh_obj.FemMesh.Volumes
aVolume = mesh_obj.FemMesh.getElementNodes(149)
Gui.ActiveDocument.Box_Mesh.HighlightedNodes = list(aVolume)
# reset
Gui.ActiveDocument.Box_Mesh.HighlightedNodes = [0]
Export the mesh to unv and open the mesh in GMSH GUI is what I do if FreeCAD is at his End in this regard ...
It's crazy that I didn't mention sooner that in FreeCAD writes on the bottom what is preselected by mouse.
Some time ago I wrote short macro for labeling element and node numbers - it creates label objects so it is unusable for big meshes. Now I put it together with some other pieces of code and experimented with gui.
https://github.com/fandaL/FreeCAD_macro ... mLabels.py
You can try it, but do not use if for whole mesh if it has more nodes (elements).
