Example of an Hex mesh with GMSH
bernd
Re: Example of an Hex mesh with GMSH
Post by bernd »
What happens if you would use different values for the symmetric edges ?
sodelo
Post by sodelo »
This is what I am exploring.
I base my tests on my old example I prepared years ago. There may be novelties. I am having a look at the documentation.
2 volumes do not have the same number of elements on the left and on the right. Resulting mesh is a free quad-dominated mesh, which is a nice possibility for transitions of density. Not sure the result is correct since there are error messages.
Edit: This mesh is not correct. I need to work on this.
makkemal
Post by makkemal »
So I finally got to redoing the demo video from last week and when I created the mesh with GMSH this is what I got.
Is some of this in the master already ?
File
funny_mesh.fcstd
(446.25 KiB) Downloaded 72 times
bernd
Post by bernd »
No not yet in master, you need to edit the geo file which is created from FreeCAD or be patient for a few days ...
sodelo
Post by sodelo »
I do not find any working solution so far to have different element numbers on 2 sides.
I will try to ask for help to the gmsh mailing list. Until then, do not count on it.
sodelo
Post by sodelo »
Double-sided progression to create surface layer.
Merge "cube.brep";
Transfinite Line "*" = 20 Using Bump 0.05;
Transfinite Surface "*";
Recombine Surface "*";
Transfinite Volume "*";
sodelo
Post by sodelo »
At least we stil have the good old partitionning mehod to change the mesh density ...
bernd
Post by bernd »
sodelo wrote:At least we stil have the good old partitionning mehod to change the mesh density ...
how does the geo for this looks like?
sodelo
Post by sodelo »
The GEO is like the previous ones.
The partition has to be done in Freecad.
Since the GMSH capabilities for Hex are somewhat limited (compared to commercial softs), we will have to do a lot of preparation on the model (volume subdivision and numbering all the edges). It would be nice to get:
- a one click solution for subdivision (instead of extrusion+booleanoperation + compound filter),
- a detection of linked edges (edges which have to get the same number of elements). This one is much more difficult :?
HoWil
Post by HoWil »
sodelo wrote:It would be nice to get:
This is what I was thinking of. Maybe one can select the top or bottom face or an extruded object and the depth info is extracted from the edges inbetween or from the extruded object.
BR
Howil
