VTK Data At Point Implementation
Nduduzo
Post by Nduduzo »
I have done the implementation of Data At Point.
Currently i am busy with Result labels at position using VTK (sticker showing value of result at specific point).
The branch can be found here:
https://github.com/stoflap/FreeCAD/tree/DataAtPoint
Feedback and comments will be much appreciated.
regards
Nduduzo
HoWil
Re: VTK Data At Point Implementation
Post by HoWil »
Nduduzo wrote:I have done the implementation of Data At Point.
regards
Nduduzo
Hi Nduduzo,
Welcome.
I am impressed. First post and a ow branch.
The tool for labeling results does sound very useful. Can you please share some screenshots.
BR Howil
Jee-Bee
Post by Jee-Bee »
What i was thinking... It would be nice if using this system also the min and max values can be found.
So kind of reversed way...
Nduduzo
Post by Nduduzo »
The Workflow is as follows:
1.Start FreeCAD.
2.Load "Data At Point example.fcstd".
DataAtPoint.fcstd
(56.07 KiB) Downloaded 132 times
3.Create Post Processing Pipeline.
4.Create a Data At Point Clip.
5.Click Select Point and Choose the Field then Apply.
6. The point is displayed below:
Currently working on the tool for labeling results at the specific point.
regards
Nduduzo
makkemal
Post by makkemal »
+1
sodelo
Post by sodelo »
Very nice work,
Could the material point be defined by a node or element label as well?
bernd
Post by bernd »
Nduduzo wrote:Currently working on the tool for labeling results at the specific point.
May I ask if there has been any update on this? Bernd
bernd
Post by bernd »
rebased on top of 0.17.10473 ... https://github.com/berndhahnebach/FreeC ... ataatpoint
compiles on Debian/Jessie. I'm playing with it ... Does some other need this too? There is rare posts in here!
bernd
Post by bernd »
The color point is so small, the point can not be found somehow. Do I miss something. How can the colored point I have selected to get results from made visible for my poor eyes ?!
Nduduzo
Post by Nduduzo »
bernd wrote:The color point is so small, the point can not be found somehow. Do I miss something. How can the colored point I have selected to get results from made visible for my poor eyes ?!
The aim for DataAtPoint is not to display color point, reason why color point displays is that i used one and the same implementation like other filters does. For DataAtPoint you select a point anywhere in an object and small color point displays then the value for that point you selected will be printed in a Console with its Unit.
Regards
Nduduzo
