vtk pipeline change source
HoWil
Post by HoWil »
I miss the feature to change the source of a vtk pipeline. Once created you do not know which result element it belongs to and changing the source would help to reuse it easier.
Is there already some possibility and I missed it?
Thx,
HoWil
bernd
Re: vtk pipeline change source
Post by bernd »
HoWil wrote:I miss the feature to change the source of a vtk pipeline. Once created you do not know which result element it belongs to and changing the source would help to reuse it easier.
Very good point. If you have made a few clip filter and stuff like that, change some load or mesh density you need to redo all the filters ... This is a needed feature, but as far as I know it goes only one direction at the moment.
bernd
Post by bernd »
Just played a bit ... FreeCAD crashes :shock: could some other confirm?
- start FreeCAD
- load FEM 3D example
- activate analysis
- select result object
- click on icon create post processing pipeline --> new object Pipeline
- run the following code:
App.ActiveDocument.Pipeline.Data
optional test the Pipeline before the crash:
- change visibility of FEM mesh to off
- couble click on the pipline
- change Mode to Surface with edges
- change Field to Displacement
- see colored post processing on screen
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.10427 (Git)
Build type: Unknown
Hash: b1347ec12b99a7f90e336ede50d935393c14bf9d
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
HoWil
Post by HoWil »
Can confirm the crashes in both cases. :D :(
BR Howil
HoWil
Post by HoWil »
Even if I completely rebuild the analysis.
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10423 (Git)
Build type: None
Hash: 45bf8ed91ed1bd65d7c5750685f8c435c9b092cf
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
fandaL
Post by fandaL »
FC do not crash. I get only a message
OS: Windows 7
Version: 0.17.9927 (Git)
Hash: 2780edd903e9819eb0d0940ca0e754f1124ac188
Python version: 2.7.8
OCC version: 7.0.0
qingfeng.xia
Post by qingfeng.xia »
I will have a look next week, after an academic report event. I have no experience on how vtk pipeline works
We should recommend user to use paraview directly, how about a command/push button in solver control panel to load result to paraview (I did it in CFD), in addition to basic view in FreeCAD. stress and displacement view in task panel is actually quick handy.
bernd wrote:Just played a bit ... FreeCAD crashes :shock: could some other confirm?
- start FreeCAD
- activate analysis
Build type: Unknown
Qt version: 4.8.6
OCC version: 7.0.0
Ubuntu 18.04 LTS 64bit, python3, always work with latest FreeCAD daily build
Working on Cfd module for FreeCAD, FreeCAD_Module_Develop_Guide
https://github.com/ukaea/parallel-preprocessor/
https://github.com/qingfengxia/Cfd
qingfeng.xia
I see there is one line in importFemREsultVTK.
"DisplacementLength should be calcuated in cpp"
yes, but I did not understand what is "DisplacementLength", is that magnitude of displacement.
Please show me the equation, I can quickly fix it.
bernd
Post by bernd »
qingfeng.xia wrote:I see there is one line in importFemREsultVTK.
in importToolsFem.py see lines https://github.com/FreeCAD/FreeCAD/blob ... #L153-L154
it is implemented in importVTKResults.py too, but this could be move to importToolsFem.py too
see lines https://github.com/FreeCAD/FreeCAD/blob ... lts.py#L95 and https://github.com/FreeCAD/FreeCAD/blob ... ts.py#L116
bernd
Post by bernd »
git commit 9568fa4 it is in importToolsFem.py only now
