Problem material library - Generic glass
HoWil
Postby HoWil » Fri Mar 10, 2017 9:53 am
I face a problem regarding the material settings for "Glass-Generic" when using FEM-materials. After selecting this material in Task-view and confirming the selection with OK the material-entry in Combo-Box->Model cant be edited any more. The material is marked with yellow background color as it is highlighted during editing it but the Task-View menu is empty.
I guess some values are wrong/missing for 'Glass-Generic'. EDIT: the same problem happens for 'AlMg3F24' and maybe others.
'Solid Material' is marked yellow but no dialogues are shown in Task-View!
Screenshot from 2017-03-10 10-46-50.png (122.22 KiB) Viewed 231 times
Steps to reproduce:
*open 3D FEM example
*change material to 'Glass-Generic' and confirm with OK
*try to reopen - FEM-material dialogue with double-clicking 'Solid-Material' in Model->Combo-View.
BR,
HoWil
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10460 (Git)
Build type: None
Hash: 91c59c7910436c44ede608e29d9a90a287121a11
Python version: 2.7.12
OCC version: 7.1.0
bernd
Re: Problem material library - Generic glass
Postby bernd » Fri Mar 10, 2017 11:17 am
confirmed on
OS: Debian GNU/Linux 8.7 (jessie)
Build type: Unknown
Branch: femdev
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
I'll have a look.
santacruz
Postby santacruz » Fri Mar 10, 2017 1:36 pm
Same problem here.
OS: Mac OS X 10.12.3
Branch: (detached from 91c59c7)
Python version: 2.7.13
OCC version: 7.1.0
bernd
Postby bernd » Sat Mar 11, 2017 4:53 pm
The value in glas material misses the unit, see https://github.com/FreeCAD/FreeCAD/blob ... .FCMat#L16
It should look like this in Steel-Generic with a valid unit https://github.com/FreeCAD/FreeCAD/blob ... .FCMat#L16 or like in https://github.com/FreeCAD/FreeCAD/blob ... .FCMat#L14 or like on Wood-Generic without any ThermalExpansionCoefficient at all, see https://github.com/FreeCAD/FreeCAD/blob ... Mat#L7-L13
bernd
Postby bernd » Sat Mar 11, 2017 5:01 pm
To be honest, I would rather like to see all wrong materials fixed than the material task panel. May be I will add some checks to get around wrong material cards anyway.
To fix the material cards this may help. viewtopic.php?f=10&t=17441
bernd
HoWil
Postby HoWil » Mon Mar 13, 2017 8:58 am
bernd wrote:To be honest, I would rather like to see all wrong materials fixed than the material task panel. May be I will add some checks to get around wrong material cards anyway.
bernd
I agree!
Will have a look on the material within the next days... cant guarantee a thing .
BR,
HoWil
bernd
Postby bernd » Mon Mar 13, 2017 11:13 am
HoWil wrote:Will have a look on the material within the next days... cant guarantee a thing .
would be cool ...
If you are interested to reproduce the problem in a python console ...
tc_new_unit = "W/m/K"
withUnit = u'43.0 W/m/K'
tc = FreeCAD.Units.Quantity(withUnit)
tc
tc_with_new_unit = tc.getValueAs(tc_new_unit)
tc_with_new_unit
withoutUnit = u'0.000009'
tc = FreeCAD.Units.Quantity(withoutUnit)
tc
bernd
Postby bernd » Fri Mar 17, 2017 11:19 am
for more informations see topic: viewtopic.php?f=10&t=21293
Implemented a work around. I extended the checks of the given material data. I may add it to all material in task panel.
https://github.com/berndhahnebach/FreeC ... diff=split
@HoWil:
Would you give this a try? It's in https://github.com/berndhahnebach/FreeC ... its/femdev
HoWil
Postby HoWil » Fri Mar 17, 2017 3:36 pm
bernd wrote:@HoWil:
Thanks for your effort!
cloning and compiling ...
HoWil
Postby HoWil » Fri Mar 17, 2017 6:56 pm
First, I tested all 7 standard material available in femdev. All worked fine.
Second, copied all 99 available materials from
/FreeCAD_bhb/src/Mod/Material/StandardMaterial
to
/FreeCAD_bhb/data/Mod/Material/StandardMaterial
and tested at least the originally mentioned Glass_Generic and AlMg3F24 and all worked also fine.
I observed that for instance AlMg3F24 was after reopening the file/material-browser changed to [DE]AlMg3F24 and the following output was printed in the terminal (Glass-Generic changed to Glass)
Previously used material cannot be found in material directories. Using transient material.
Is this because some parameters were not imported and set to 0?
Thanks again,
HoWil
