Creating a group of nodes for a volume
sodelo
Postby sodelo » Mon Mar 20, 2017 7:01 pm
Is there a simple way to define a Boundary conditions for a group of nodes related to a volume?
I tried different ways without success (Fem Mesh Group or Node Sets). In the end, I do not find the node set in the Input file.
Thanks,
Sodelo
bernd
Re: Creating a group of nodes for a volume
Postby bernd » Mon Mar 20, 2017 7:18 pm
The material object has it. All other objects only uses faces, edges or vertices. See attached multi body analysis. The inp file has two volume element sets:
*ELSET,ELSET=SolidMaterialSolid
*ELSET,ELSET=SolidMaterial001Solid
multibody.fcstd
(352.54 KiB) Downloaded 11 times
bernd
Postby bernd » Mon Mar 20, 2017 7:24 pm
sodelo wrote:Is there a simple way to define a Boundary conditions for a group of nodes related to a volume?
The problem is, the inp exporter does not support mesh groups. the mesh group object is mainly used by people working with FEM meshes exported to med and unv. These both exporter does support groups. We really need to get the inp writer support groups and mixed meshes. Ahh see viewtopic.php?p=162988#p162988
The node sets (defined with the node set tool) are not used by any other tool, as far as I know.
sodelo
Postby sodelo » Mon Mar 20, 2017 7:42 pm
Thanks for the information.
So there is no simple workaround since I need a node set and not an element set.
bernd
Postby bernd » Mon Mar 20, 2017 7:54 pm
sodelo wrote:Thanks for the information.
Not with the gui, but you can get the nodes by python quite easy ...
- open the file I posted earlier
- run the code ...
mysolid = App.ActiveDocument.CompoundFilter.Shape.Solids[0]
mymesh = App.ActiveDocument.CompoundFilter_Mesh.FemMesh
yournodes = mymesh.getNodesBySolid(mysolid)
yournodes will be a list of the nodes you need ...
bernd
Postby bernd » Mon Mar 20, 2017 8:02 pm
to write them to file use:
filename = '/tmp/yournodes.inp'
f = open(filename, "wb")
f.write("*NSET,NSET=yournodeset\n")
for n in yournodes:
    f.write(str(n) + ",\n")
f.close()
ulrich1a
Postby ulrich1a » Mon Mar 20, 2017 8:14 pm
sodelo wrote:So there is no simple workaround since I need a node set and not an element set.
I have used cgx for this purpose. Open the inp-file inside of cgx, for example the Box_mesh.inp which you get from the FreeCAD FEM-samples:
cgx -c Box_mesh.inp
The command
prnt se
lists all sets. An element set can be upgraded to also contain its nodes with the command
comp Eall do
This adds all nodes to the element set Eall. Now the nodes (and the elements) can be written to a file, which can be included into the inp-file:
send Eall abq names
This gives a file Eall.nam, which contains a node set and an element set. Include this file into your inp-file.
Ulrich
sodelo
Postby sodelo » Tue Mar 21, 2017 6:58 am
Thanks to both of you for your help.
bernd
Postby bernd » Tue Mar 21, 2017 7:21 am
since there are so many constraints we gone not support, we may add an generic constraint object, similar to the mesh region object, but directly dedicated to the analysis.
bernd
