Enforced pressure-constraint in static analysis
nicoguaro
Post by nicoguaro »
I am trying to run a simulation where I impose a displacement in a cantilever beam. In this case, there is no imposition of tractions. There will be stresses as reactions to the imposed displacement, but FreeCAD is not allowing this case.
This is the error that I get
OS: Windows 8.1
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
fandaL
Re: Enforced pressure-constraint in static analysis
Post by fandaL »
For using FEM module download 0.17 dev version, e.g.
 FreeCAD_0.17.10634_x64_dev_win.7z
from https://github.com/FreeCAD/FreeCAD/releases
Prerequisities are fixed there and you will find a lot of new features.
nicoguaro
Post by nicoguaro »
It works, as you mentioned. Thanks.
The post-processing is not clear though.
UR_
Post by UR_ »
Attached you can find a small example.
Left face is fixed, right face gets a displacement of 10 mm.
Ringauge.FCStd
(22.34 KiB) Downloaded 61 times
if you are interested in reaction forces caused by this deflection, you have to edit ccx-input-file (here Fillet_mesh.inp)
before ccx's execution
Please insert reddish output request by hand
** Outputs --> frd file
** written by write_outputs_types function
*NODE FILE
U
*EL FILE
S, E
** outputs --> dat file
*NODE PRINT , NSET=Nall
U
*NODE PRINT , NSET=FemConstraintFixed, TOTALS=ONLY
RF
*EL PRINT , ELSET=Eall
S
In ccx-output-file (Fillet_mesh.dat) you can find that 42000 N needs to be loaded
total force (fx,fy,fz) for set FEMCONSTRAINTFIXED and time 0.1000000E+01
-4.230049E+04 2.246115E-07 5.220707E-08
Fillet_Mesh_INP_DAT files.zip
(139.91 KiB) Downloaded 63 times
Let us know if you are looking for something else :roll:
bernd
Post by bernd »
issue #2934
updated file to 0.19 ...
Ringauge-2.FCStd
(278.63 KiB) Downloaded 50 times
bernd
Post by bernd »
an file updated be the original author can be found here: https://forum.freecadweb.org/viewtopic. ... 49#p312618
