Static FEA of a Flanged Pressure Vessel
bernd
Re: Error Displaying CalculiX Results in v0.17
Post by bernd »
Just a question in the regard of precision to CalculiX cracks around ...
We implemented double precision in inp exporter (git commit e58b747) but the ccx results are double precision only. Means we do not have any benefit do we ?!?
Is it possible to change precision of result to double too? As example see a frd of the unit test: https://github.com/FreeCAD/FreeCAD/blob ... static.frd
ulrich1a
Post by ulrich1a »
bernd wrote:Is it possible to change precision of result to double too?
I could not find an answer to this in the ccx-manual.
The frd-result-format is a format specification from an former FEM-code which did exist before calculix. The available format options are shown here: http://www.feacluster.com/CalculiX/cgx_ ... de188.html
A binary format with double precision does exist. Calculix is able to write the binary format, if the *NODE OUTPUT is used: https://www.feacluster.com/CalculiX/ccx ... de266.html
But I could not find a hint in the manual, if it writes single or double precision. One has to analyze the resulting frd-file in order to find out. The next step is to find out, if FreeCAD is able to import binary result files.
Anyway, the subtraction operation amplifies rounding errors, so I expect the enhancement of the input-file precision is not useless.
Ulrich
Edit: For a mixed ascii/binary format file, both *NODE OUTPUT and *ELEMENT OUTPUT must be used. The node coordinates are written with double, the results are written as binary float.
Doug
Post by Doug »
I have been trying different GMSH settings to see if I can eliminate these 'lonely' nodes. I tried turning on the higher order mesh optimization, but it had no effect. I looked at the source code, and I believe I can see why it didn't work. The following code is from FemGmshTools.py starting at line 367:
        # hight order mesh optimizing
        if hasattr(self.mesh_obj, 'OptimizeNetgen') and self.mesh_obj.OptimizeNetgen is True:
            geo.write("Mesh.HighOrderOptimize = 1;  //probably needs more lines off adjustment in geo file\n")
        else:
            geo.write("Mesh.HighOrderOptimize = 0;  //probably needs more lines off adjustment in geo file\n")
I believe the code should be:
        # higher order mesh optimizing
        if hasattr(self.mesh_obj, 'HighOrderOptimize') and self.mesh_obj.HighOrderOptimize is True:
            geo.write("Mesh.HighOrderOptimize = 1;  //probably needs more lines of adjustment in geo file\n")
        else:
            geo.write("Mesh.HighOrderOptimize = 0;  //probably needs more lines of adjustment in geo file\n")
With this modification, I found the mesh optimization worked.
Cheers,
Doug
bernd
Post by bernd »
Doug wrote: Tue Jun 20, 2017 3:52 amWith this modification, I found the mesh optimization worked.
Thanks Doug for triggering this out ... https://github.com/FreeCAD/FreeCAD/pull/826
UR_
Post by UR_ »
Doug wrote: Tue Jun 20, 2017 3:52 am With this modification, I found the mesh optimization worked.
This might be true, but these lonely nodes are not gone. :?
tested with:
Version: 0.17.11432 (Git)
Hash: 0768ae99cfd6036601f66658f6e0f923de9af6f2
Python version: 2.7.8
OCC version: 7.1.0
gmsh_3.0.3.exe
ccx_2.12_MTNO.exe
ccx gives this message even with: Mesh.HighOrderOptimize = 1;
*ERROR: in gen3dboun: node 3 does not
belong to a beam nor shell
element and consequently has no
rotational degrees of freedom.
This may be caused by applying
a local coordinate system to a
node in which a rotational boundary
conditions is defined. In CalculiX
this is not allowed.
But there is a feature inside gmsh to get rid of these nodes.
gmsh's input file "shape2mesh.geo" needs 2 additional lines in meshing section.
After that, gmsh merges all nodes with a distance less than given tolerance.
(red lines are added manually)
// meshing
Geometry.Tolerance = 1e-3; // set tolerance for merging nodes
Mesh 2;
Coherence Mesh; // Remove duplicate entities
Here is an example file with 2 meshes inside, one generated the old way, and one with activated coherence.
Please dragndrop one of them into analysis, and see the difference.
SphereTest.FCStd
(113.54 KiB) Downloaded 43 times
screenshot result with coherence.png (82.42 KiB) Viewed 1969 times
Perhaps one can add a coherence ON/OFF-flag and a coherence tolerance to "FEM GMSH Mesh Params" :roll:
bernd
Post by bernd »
I'l add them ...
Doug
Post by Doug »
UR_ wrote: Sat Jun 24, 2017 11:20 pm
// meshing
Mesh 2;
Thanks very much, UR_! :D I've been stumped on these lonely nodes for some time now.
By the way, when I said that mesh optimization now worked, I didn't mean that it fixed the lonely node problem, just that the .geo file was now triggering mesh optimization as intended.
Cheers,
Doug
bernd
Post by bernd »
as a hint, be careful in setting the tolerance to hight, you might get non-positive jacobians than. Thus default in FreeCAD is quite small with 1e-6
Doug
Post by Doug »
bernd wrote: Sat Jul 01, 2017 7:17 am as a hint, be careful in setting the tolerance to hight, you might get non-positive jacobians than. Thus default in FreeCAD is quite small with 1e-6
Thanks, Bernd :) Indeed, I found 1E-3 was too large and resulted in many missing mesh elements. For my model, 1E-5 worked nicely.
Cheers,
Doug
