Element Membrane M3D6
Groguigui
Post by Groguigui »
I would like to simulate a spherical shell with internal pressure, like a ball, with hyperelastic material (Neo Hooke and Yeoh), to compare with analytical solution.
But the model never converges, always for same reason :
"*ERROR : too many cutbacks
best solution and residuals are in the frd file"
I test some solver and different increment (direct, iteratif, cholesky, explicit, in INP writing).
1) Do you know if calculix can solve spherical shell problem?
2) How can I change cutbacks?
3) Which solver is it better?
May be it will be better to ask this question at Guido Dhondt, because it is a calculix problem...
sodelo
Re: ERROR : too many cutbacks
Post by sodelo »
I suspect you face a problem of material instability (well known for elasto-plasticmaterials).
- Please try first with an elastic material --> it should cpnvergence with the static solver
- then for a elasto-plastic material (for example sigma=KEps^n). I do not exactly remember the formula but if n=0.18, you should get the instability when EpsBar (equivalent plastic strain) is around 0.12.
To solve this, best solver is dynamic, implicit. You need inertia to stabilize the solution.
Try something like,
*Dynamic
0.01,1.,1e-7,0.01
BR
makkemal
Post by makkemal »
Activate user defined incrementation , the defaults tend to not be sufficient when dealing with non-linear problems.
Then set the control parameters manually
Groguigui
Post by Groguigui »
Thanks,
Finally, I found how solve my problem : I used *Controls fonction to set increments and cutbacks. :P
http://web.mit.edu/calculix_v2.7/Calcul ... de179.html
bernd
Post by bernd »
Groguigui wrote:I used *Controls fonction to set increments and cutbacks. :P
you can set them in FreeCAD CalculiX solver object too. Means no need to edit the input file.
Groguigui
Post by Groguigui »
Yes Bernd, I saw, but I think isn't possible to set cutback in FreeCAD. Anyway, actually I have another problem. :lol:
Do you know why FreeCAD solve a stress in third dimension when we use a shell element? Usually, it must be zero with plane stress hypothesis.
Actually I would like to solve a hyperelastic spherical problem under pressure. But I don't understand why results are different to analytic solution.
fandaL
Post by fandaL »
Results in local coordinate system are new for shell elements in ccx 2.12 * ccx 2.12 creates automatically local coordinate system for shell elements, but projecting of global x-axis could be strange for elements with normal direction close to x-direction.
For shells a local coordinate system is automatically established by projecting the global or local (if defined by the user) x-axis on the shell surface.
from http://www.dhondt.de/new_calc.htm
Older versions print stresses in a global c.s.! * results are by default in the global c.s. The local coordinate system must be triggered in the .inp file by
*EL FILE, global=no
S, E
Plane stress (or plane strain) needs special element types which can be used only on 2D model in xy plane in Calculix. So I would expect nonzero normal stresses on your shell elements.
*EDITED
Groguigui
Post by Groguigui »
So I would expect non zero normal stresses on your shell elements.
And you're right!
I understand, that is why I have non zero normal stresses, because applied pressure is normal on my shell elements. In fact I didn't work with plane stress hypothesis.
1) How can I find this elements types? Does it exist actually in FreeCAD? In calculix?
2) What calculix version is in FreeCAD 0.17? I don't know where is this information.
3) Sorry I have already ask this question, but I forgot the answer, it is possible to solve a problem with shell AND volumic mesh with calculix and/or freeCAD? Like a volumic cube with different materials on each faces and inside.
fandaL
Post by fandaL »
You can look to the manual http://www.feacluster.com/CalculiX/ccx_2.11/doc/ccx/ under Theory/Element Types there are several plane stress elements. After writing .inp file in FreeCAD you can search in the file line like
*Element, TYPE=S6, ELSET=Eall
and change from S6 (shell) to CPS6 (plane stress) element type
However, it will most probably fail on spherical model. You can define plane stress elements only in xy plane.
2.8p or 2.11 You can find it, when you click “Run Calculix”, in the beginning of the printed log
Discussion about 2.12 https://forum.freecadweb.org/viewtopic.php?f=18&t=21680
It should be possible in CalculiX. FreeCAD does not yet support meshes combining 2D and 3D elements.
UR_
Post by UR_ »
Freecad bundles pretty outdated ccx.exe. So better upgrade to ccx2.12.
If you have a 3d-shape like a balloon, and you have to avoid bending stress. then membrane elements are first choose.
See http://www.dhondt.de/ccx_2.12.pdf
Page 92 cit:
6.2.14 Three-node membrane element (M3D3)
This element is similar to the S3 shell element except that it cannot sustain
bending. This is obtained by modelling hinges in each of the nodes of the
element. Apart from that, all what is said about the S3 element also applies
here.
Membrane elements could not bend. They stay plain in space.
External forces (and pressure loads) are applied normal to membrane's face
Internal forces are aligned tangentialy to membrane's face and leads to plain deformation.
Curvature is only done on element's edges.
