Failed on enumerating of Faces
UR_
Post by UR_ »
there seems to be an issue, if more than one FemPressureConstrain object is used.
This is a box made from shells. There is one pressure object with two loads inside.
1 FemConstrainPressureObj with 2 loads.png (17.66 KiB) Viewed 1147 times
Result doesn't look so bad, despite faulty load/deflection directions (but that's another movie)
box of shells - 1 FemConstrainPressureObj with 2 loads.png (264.96 KiB) Viewed 1147 times
Now we split pressure loads into 2 objects.
2 FemConstrainPressureObjs 1 load each.png (20.17 KiB) Viewed 1147 times
Deflection is zero :shock:
box of shells - 2 FemConstrainPressureObj with 1 load each.png (102.5 KiB) Viewed 1147 times
In latter case, let's have a look into ccx's input file.
Both emitted node sets are identical. Therefore loads (+100 and -100) are zeroed out.
That should be avoided. ;)
Used files:
boxunderpressure.zip
(189.93 KiB) Downloaded 20 times
Done with:
Version: 0.17.10802 (Git)
Hash: 10ce910c03347a90712327a7cc7be2bcdee13afc
Python version: 2.7.8
OCC version: 7.0.0
bernd
Re: Failed on enumerating of Faces
Post by bernd »
Does it work for you with solid mesh?
UR_
Post by UR_ »
Sorry, but solids are broken too :(
bernd
Post by bernd »
damn ... I'll have look ... We really need more unit tests. For sure this has been working with solid meshes ...
bernd
Post by bernd »
UR_ wrote:Sorry, but solids are broken too :(
In the regard of solid mesh. It works for me if
either:
- Netgen mesh object is used
or
- the GMSH mesh object is moved outside the analysis, the shape is meshed and the GMSH mesh object is moved back inside the analysis. (check the mesh object, it should not have any groups !)
What's the culprit ? The GMSH mesh object if used inside an analysis creates mesh groups at meshing. These groups are used for writing the input file. There is some bug. If the mesh object is meshed outside the analysis no groups are created and some algorithm is used to get the appropriate data for writing the input file. (BTW this algorithm is pretty fast thanks to ulrich :) ) There is no bug in this algorithm :D
bernd
Post by bernd »
this https://github.com/berndhahnebach/FreeC ... diff=split should fix it for all kind of pressure constraints with all kind of solid mesh objects.
