2D Mesh
bernd
2D Mesh
Postby bernd » Sun Sep 28, 2014 9:54 am
In structural engineering field all FEM models are made with 2D and 1D elements. I'm able to import the meshes from the calculation software we use at the office into FreeCAD. :D
In Fem_Workbench is shown how to make a FEM Mesh using python but only for 3D-meshes :(
These two posts of Juegen gave some informations about FEM-module.
viewtopic.php?f=18&t=6963#p56362
viewtopic.php?f=18&t=6992&start=10#p57065
The mesh object can allready handle 2D-Meshes. Does it mean if I create my Mesh in python (by converting the imported mesh) I am able to use the 2Dmesh object? It would mean I could show the nodes on the screen but not the mesh since the 2D meshes do not have visuals yet?
I wonder if it is possible by python to put even constraints on the 2D mesh by python and make a analysis in calculix? Attached a simple slab I would like to play with.
simpleslab--structural.fcstd
(49.86 KiB) Downloaded 45 times
ediloren
Re: 2D Mesh
Postby ediloren » Sun Sep 28, 2014 11:00 am
If you mean, meshing the surface of the objects, this is perfectly possible, also from the gui. Look under 'mesh part' (sorry i'm not in front of my computer now, cannot post a screenshot)
Enrico
bernd
Re: 2D Mesh
Postby bernd » Sun Sep 28, 2014 3:45 pm
ediloren wrote:If you mean, meshing the surface of the objects ...
I allready have a mesh. I would like to turn it into a FEM-Mesh
import FreeCAD, Fem
m = Fem.FemMesh()
m.addNode(0,1,0)
m.addNode(0,0,1)
m.addNode(1,0,0)
m.addFace([1,2,3])
Fem.show(m)
Gui.ActiveDocument.ActiveObject.HighlightedNodes = [1,2,3]
Shows the points of the little FEM-Mesh, is it a FEM-Mesh? If it's a FEM-Mesh that would mean a FEM-Mesh could be made from the imported Parts this way! :) How to add constraints to that FEM-Mesh? I know the node numbers to add to. Same for loads ...
bernd
Re: 2D Mesh
Postby bernd » Mon Sep 29, 2014 8:08 pm
The code of the last post seam to made a FEM-Mesh, just forgot to print it ...
>>> m
========================== Dump contents of mesh ==========================
1) Total number of nodes:      3
2) Total number of edges:      0
3) Total number of faces:      1
4) Total number of polygons:   0
5) Total number of volumes:   0
6) Total number of polyhedrons:   0
7) Total number of linear edges:   0
8) Total number of linear faces:   1
8.1) Number of linear triangles:     1
8.2) Number of linear quadrangles:   0
9) Total number of linear volumes:   0
10) Total number of quadratic edges:   0
11) Total number of quadratic faces:   0
12) Total number of quadratic volumes:   0
bernd
Re: 2D Mesh
Postby bernd » Mon Sep 29, 2014 8:13 pm
Mhh but trying to get a Mesh out of the file provided (simpleslab--structural.fcstd) addNode does not accept a Point :(
>>> import FreeCAD, Fem
>>> m = Fem.FemMesh()
>>> testnode = App.ActiveDocument.ID1009954_Entry__1009950_body.Shape.Faces[0].Edges[0].Vertexes[0].Point
>>> testnode
Vector (5.0, -2.5, 3.125)
>>> m.addNode(testnode)
TypeError: addNode() accepts:
-- addNode(x,y,z)
-- addNode(x,y,z,ElemId)
bernd
Re: 2D Mesh
Postby bernd » Mon Sep 29, 2014 8:21 pm
Mhh sorry for posting that much ...
Just correcting myself ...
>>> import FreeCAD, Fem
>>> m = Fem.FemMesh()
>>> nx=testnode.X
>>> ny=testnode.Y
>>> nz=testnode.Z
>>> m.addNode(nx,ny,nz)
1
>>> m
1) Total number of nodes:      1
3) Total number of faces:      0
8) Total number of linear faces:   0
bernd
Re: 2D Mesh
Postby bernd » Mon Sep 29, 2014 9:10 pm
Got the Mesh, but FreeCAD crashes ...
load the file:
import FreeCAD, Fem
faces = App.ActiveDocument.ID1009954_Entry__1009950_body.Shape.Faces
m = Fem.FemMesh()
nodeid = 1
for f in faces:
  vertiece = f.Vertexes
  for vnr, v in enumerate(vertiece):
    vx = v.X
    vy = v.Y
    vz = v.Z
    #print '(', vx, ', ', vy, ', ', vz, ', ', nodeid, ')'
    m.addNode(vx,vy,vz,nodeid)
    nodeid += 1
    if vnr == 0:
      facenode1 = nodeid
    elif vnr == 1:
      facenode2 = nodeid
    elif vnr == 2:
      facenode3 = nodeid
    else:
      print 'error in facenodes'
  m.addFace([facenode1,facenode1,facenode1,])
Fem.show(m)
m
# aktivate Mesh in TreeView
list = range(m.NodeCount+1)
list = list[1:]
Gui.ActiveDocument.ActiveObject.HighlightedNodes = list
do not change the view. Just zoom in and out using the mouse wheel and FreeCAD crashes. I can remember this again and again. I havn't had this with this version of FreeCAD with non of lots of modells.
OS: Windows 7
Word size: 64-bit
Version: 0.14.3691 (Git)
Hash: 691fd1128672c8bd472cece87c9e9d07b71d6fee
Python version: 2.7.6
Qt version: 4.8.5
SoQt version: 1.6.0a
bernd
Re: 2D Mesh
Postby bernd » Mon Sep 29, 2014 9:19 pm
same crash on:
OS: Ubuntu 14.04.1 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.15.4086 (Git)
Hash: f87bd2ac352dee9ea9aa27096141e0a37326fa45
Qt version: 4.8.6
bhb@ubuntuVM:~$ freecad
FreeCAD 0.15, Libs: 0.15R4086 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2014
libGL error: pci id for fd 15: 80ee:beef, driver (null)
OpenGL Warning: Failed to connect to host. Make sure 3D acceleration is enabled for this VM.
libGL error: core dri or dri2 extension not found
libGL error: failed to load driver: vboxvideo
sh: 1: SMDS_MemoryLimit: not found
*** Abort *** an exception was raised, but no catch was found.
   ... The exception is:SIGSEGV 'segmentation violation' detected. Address 1e4
bhb@ubuntuVM:~$
BTW: ubuntu runs in VirtualBox
shoogen
Re: 2D Mesh
Postby shoogen » Tue Sep 30, 2014 6:44 pm
i can reproduce the problem
#0  0x00007fff6699c1fc in FemGui::ViewProviderFemMesh::getElement (this=
    0x52d4ce0, detail=0x5304920)
    at /home/sebastian/free-cad/src/Mod/Fem/Gui/ViewProviderFemMesh.cpp:420
#1  0x00007ffff75c85f9 in Gui::SoFCUnifiedSelection::handleEvent (this=
    0x24ffc30, action=0x96deb0)
    at /home/sebastian/free-cad/src/Gui/SoFCUnifiedSelection.cpp:363
#2  0x00007ffff4df6707 in SoNode::handleEventS(SoAction*, SoNode*) ()
   from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#3  0x00007ffff4bbbc85 in SoAction::traverse(SoNode*) ()
#4  0x00007ffff4d06f3c in SoChildList::traverse(SoAction*, int, int) ()
#5  0x00007ffff4debf5d in SoGroup::doAction(SoAction*) ()
#6  0x00007ffff4e082bf in SoSeparator::doAction(SoAction*) ()
#7  0x00007ffff4df6707 in SoNode::handleEventS(SoAction*, SoNode*) ()
#8  0x00007ffff4bbbc85 in SoAction::traverse(SoNode*) ()
#9  0x00007ffff4bc690a in SoHandleEventAction::beginTraversal(SoNode*) ()
#10 0x00007ffff4bbc4c2 in SoAction::apply(SoNode*) ()
#11 0x00007ffff4d25499 in SoEventManager::actuallyProcessEvent(SoEvent const*)
    () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#12 0x00007ffff762d1b8 in SIM::Coin3D::Quarter::QuarterWidget::processSoEvent (
    this=0x96a0a0, event=0x39a1b70)
    at /home/sebastian/free-cad/src/Gui/Quarter/QuarterWidget.cpp:807
#13 0x00007ffff7638435 in SIM::Coin3D::Quarter::SoQTQuarterAdaptor::processSoEvent (this=0x96a0a0, event=0x39a1b70)
    at /home/sebastian/free-cad/src/Gui/Quarter/SoQTQuarterAdaptor.h:93
#14 0x00007ffff765fa83 in Gui::View3DInventorViewer::processSoEventBase (this=
    0x96a0a0, ev=0x39a1b70)
    at /home/sebastian/free-cad/src/Gui/View3DInventorViewer.cpp:1515
#15 0x00007ffff7646b2f in Gui::NavigationStyle::processSoEvent (this=
    0x24d0710, ev=0x39a1b70)
    at /home/sebastian/free-cad/src/Gui/NavigationStyle.cpp:1263
#16 0x00007ffff764b7cc in Gui::CADNavigationStyle::processSoEvent (this=
    at /home/sebastian/free-cad/src/Gui/CADNavigationStyle.cpp:436
#17 0x00007ffff7646a7c in Gui::NavigationStyle::processEvent (this=0x24d0710,
    ev=0x39a1b70) at /home/sebastian/free-cad/src/Gui/NavigationStyle.cpp:1246
#18 0x00007ffff765fa4a in Gui::View3DInventorViewer::processSoEvent (this=
    at /home/sebastian/free-cad/src/Gui/View3DInventorViewer.cpp:1510
#19 0x00007ffff762f535 in SIM::Coin3D::Quarter::EventFilter::eventFilter (this=
    0x24c9b20, obj=0x96a0a0, qevent=0x7fffffffbfc0)
    at /home/sebastian/free-cad/src/Gui/Quarter/EventFilter.cpp:164
#20 0x00007ffff0c6acc6 in QCoreApplicationPrivate::sendThroughObjectEventFilters (this=<optimized out>, receiver=0x96a0a0, event=0x7fffffffbfc0)
    at kernel/qcoreapplication.cpp:1025
#21 0x00007ffff17226dc in QApplicationPrivate::notify_helper (this=this@entry=
    0x8161a0, receiver=receiver@entry=0x96a0a0, e=e@entry=0x7fffffffbfc0)
    at kernel/qapplication.cpp:4552
#22 0x00007ffff17273eb in QApplication::notify (this=<optimized out>, receiver=
    0x24f6330, e=0x7fffffffc550) at kernel/qapplication.cpp:4099
#23 0x00007ffff73ded7b in Gui::GUIApplication::notify (this=0x7fffffffd0f0,
    receiver=0x24f6330, event=0x7fffffffc550)
    at /home/sebastian/free-cad/src/Gui/Application.cpp:1537
#24 0x00007ffff0c6ab5e in QCoreApplication::notifyInternal (this=
    0x7fffffffd0f0, receiver=0x24f6330, event=0x7fffffffc550)
    at kernel/qcoreapplication.cpp:915
#25 0x00007ffff172354b in sendEvent (event=<optimized out>,
    receiver=<optimized out>)
    at ../../include/QtCore/../../src/corelib/kernel/qcoreapplication.h:231
#26 QApplicationPrivate::sendMouseEvent (receiver=0x24f6330, event=
    0x7fffffffc550, alienWidget=0x0, nativeWidget=0x24f6330, buttonDown=
    0x7ffff21f82a8, lastMouseReceiver=..., spontaneous=true)
OS: Debian GNU/Linux 7.6 (wheezy)
Version: 0.15.4090 +7 (Git)
Branch: split-revision,review-unicode-filenames,sketcher-geoidcheck,dev-openscad
Hash: b8e3df17b264367569b2e5ace0d5112d08cfb421
Python version: 2.7.3
Qt version: 4.8.2
shoogen
Re: 2D Mesh
Postby shoogen » Tue Sep 30, 2014 6:52 pm
(gdb) p vNodeElementIdx
$2 = std::vector of length 0, capacity 0
