OS: Linux
Version: 0.16.6018 (Git)
Build type: Unknown
Branch: makepkg
Hash: c67b2bed45ac8b7bf6f7eda3c22541a26fce571a
Python version: 2.7.10
Coin version: 3.1.3
OCC version: 6.9.0
Wrong angle contstraint calculation in freecad (FreeCAD -> New -> Part Design -> Create Sketch -> two lines (connected or not - not important) -> Fix the the angle of a line ... ):
- Fixed constraint: 120 dg = OK
- Calculated contstraint: 360/3 = 6.875.49 dg after recaclulation
Screencast captured here: https://youtu.be/DcFnlolUokQ
Is it bug or my misunderstanding?
UPDATE: something wrong within convertaions of units: if i'll use radians notation in formula - all good - (2*pi) / 2 = 120 degrees IN sketch area (ignoring formula results in input form).
Sametime Distance and Lenght constraints with simple formulas seems working OK (very nice feature ).
possible bug in angle constraint formula?
- DeepSOIC
Re: possible bug in angle constraint formula?
Confirmed. When using expressions, I can't get it to correctly parse degrees units for angles in sketcher. Something strange is going on.
My version is rather old, though...
OS: Windows 8.1
Version: 0.16.5702 (Git)
Branch: FreeCAD-DeepSOIC4
Hash: df63cb8957ef4cc6f30f2aeb11c2cc5a16f799f1
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
OS: Windows 8.1
Qt version: 4.8.6
OCC version: 6.7.1
This happens because angle constraints are stored in radians, and not degrees internally. Not sure how I missed that during the expressions support implementation in Sketcher There's a special case for angles in the setDatum(...) function.DeepSOIC wrote:Confirmed. When using expressions, I can't get it to correctly parse degrees units for angles in sketcher. Something strange is going on.
Fix for test at: https://github.com/eivindkv/free-cad-co ... ns_fixes_3
Eivind
Eivind,
while you are add it, I think the same happens for the angle in placement. It works correctly with adding "pi" s expressions, which is converted to 180°, but fails if one enters "180°".
Could you please test the branch mentioned above? I've pushed a change that should fix this for the Placement property now. I've also fixed a couple of precision related things.ickby wrote:Eivind,
Eivind
