ian.rees
Posts: 696 Joined: Sun Jun 15, 2014 3:28 am
Post
by ian.rees » Mon Apr 18, 2016 11:32 pm
MacOS 10.10, debug build from "6b1c433 FEM: Results can now be double-clicked to show their task panel"
To reproduce:
Open FreeCAD
Part Design Workbench
New Document
New Part
Create an additive primitive
Click cancel in the task pane
Crash
-Ian-
Process 27408 stopped
* thread #1: tid = 0x925fdd, 0x00000001013b141c libFreeCADApp.dylib`App::DocumentObject::getDocument(this=0x0000000023090c92) const + 12 at DocumentObject.cpp:216, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x23090dba)
frame #0: 0x00000001013b141c libFreeCADApp.dylib`App::DocumentObject::getDocument(this=0x0000000023090c92) const + 12 at DocumentObject.cpp:216
213
214 App::Document *DocumentObject::getDocument(void) const
215 {
-> 216 return _pDoc;
217 }
218
219 void DocumentObject::setDocument(App::Document* doc)
(lldb) bt 10
* frame #0: 0x00000001013b141c libFreeCADApp.dylib`App::DocumentObject::getDocument(this=0x0000000023090c92) const + 12 at DocumentObject.cpp:216
frame #1: 0x000000011b5503be Part.so`Part::BodyBase::findBodyOf(f=0x0000000023090c92) + 30 at BodyBase.cpp:55
frame #2: 0x000000011fa5ec85 _PartDesign.so`PartDesign::Body::findBodyOf(feature=0x0000000023090c92) + 21 at Body.cpp:259
frame #3: 0x000000011f7a7857 PartDesignGui.so`PartDesignGui::TaskDatumParameters::~TaskDatumParameters(this=0x0000000120d554a0) + 87 at TaskDatumParameters.cpp:775
frame #4: 0x000000011f7a7a55 PartDesignGui.so`PartDesignGui::TaskDatumParameters::~TaskDatumParameters(this=0x0000000120d554a0) + 21 at TaskDatumParameters.cpp:773
frame #5: 0x000000011f7a7ad9 PartDesignGui.so`PartDesignGui::TaskDatumParameters::~TaskDatumParameters(this=0x0000000120d554a0) + 25 at TaskDatumParameters.cpp:773
frame #6: 0x00000001004799ce libFreeCADGui.dylib`Gui::TaskView::TaskDialog::~TaskDialog(this=0x0000000120d55e70) + 446 at TaskDialog.cpp:49
frame #7: 0x000000011f7c3dc1 PartDesignGui.so`PartDesignGui::TaskPrimitiveParameters::~TaskPrimitiveParameters(this=0x0000000120d55e70) + 65 at TaskPrimitiveParameters.cpp:639
frame #8: 0x000000011f7c3de5 PartDesignGui.so`PartDesignGui::TaskPrimitiveParameters::~TaskPrimitiveParameters(this=0x0000000120d55e70) + 21 at TaskPrimitiveParameters.cpp:637
frame #9: 0x000000011f7c3e09 PartDesignGui.so`PartDesignGui::TaskPrimitiveParameters::~TaskPrimitiveParameters(this=0x0000000120d55e70) + 25 at TaskPrimitiveParameters.cpp:637
DeepSOIC
Posts: 7896 Joined: Fri Aug 29, 2014 12:45 am
Post
by DeepSOIC » Tue Apr 19, 2016 12:37 am
Yep, crashes!
OS: Windows 8.1
Version: 0.17.7419 (Git)
Hash: 6b1c433807dddb0c924e2869df49df534b270340
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
nemesis
Posts: 373 Joined: Tue Mar 25, 2014 11:24 pm
Post
by nemesis » Sat Apr 23, 2016 9:19 am
also crash on cancelling "create a substractive primitive"
OS: Mac OS X
Version: 0.17.7437 (Git)
Branch: (detached from b08a75b)
Hash: b08a75bfb2583baf710c3ae95c7b8227bbdc8daf
Python version: 2.7.11
Coin version: 3.1.3
FreeCAD 0.17, Libs: 0.17R7437 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
Coin warning in cc_glglue_instance(): Error when setting up the GL context. This can happen if there is no current context, or if the context has been set up incorrectly.
2016-04-23 10:56:57.630 FreeCAD[812:26700] modalSession has been exited prematurely - check for a reentrant call to endModalSession:
Gui::DocumentItem::slotChangedObject(): Group references unknown object.
*** Abort *** an exception was raised, but no catch was found.
... The exception is:SIGSEGV 'segmentation violation' detected. Address 128
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions...none found.
Posts: 18589 Joined: Sat Feb 06, 2010 9:52 pm
Post
by NormandC » Sat Apr 23, 2016 7:26 pm
ian.rees wrote: To reproduce:
Open FreeCAD
New Document
New Part
Crash
When creating a new Part, what I get is this error dialog:
No active body
In order to use PartDesign you need an active Body object in the document. Please make one active (double click) or create one. If you have a legacy document with PartDesign objects without Body, use the transfer function in PartDesign to put them into a Body.
Did you mean New Body?
When actually creating a Body rather than a Part, I get a crash as well.
OS: Ubuntu 14.04.4 LTS
Version: 0.17.7423 (Git)
Build type: Unknown
Hash: bfaa8799edba35ae1609edb6205aaeacf37b73ff
Python version: 2.7.6
Qt version: 4.8.6
Posts: 20307 Joined: Thu Feb 19, 2009 10:32 am
Post
by wmayer » Sun Apr 24, 2016 12:19 pm
git commit 6b4821a fixes the crash.
When pressing the Cancel button the pending transactions are rolled back and thus causes the deletion of various view providers. The class TaskDatumParameters has the member DatumView that will become a dangling pointer. In the destructor of TaskDatumParameters this dangling pointer is accessed and thus causes the segmentation fault.
