splain, bezier curve
I need splain in part design workbench, is it a way to add it? (splain and bezier curve are just in draft workbench)
Re: splain, bezier curve
You can use the draft spline and bezier curves in PartDesign, however, it is not very well supported and may require some workarounds.
As we are in the developer forum there is annother option, you can add it simply by implementing the required sketcher code for spline/bezier constraints. All other code for evaluating and displaying etc is available.
ok, I did that, I added splain, tried to use it... but then Addons Installer appears... what to choose?
hi
addon installer is for install macros
for the button you must create one toolbar and choice the button for it
if you create one toolbar in the "Global" your toolbar is always visible
mario
mario
