Unused Sketcher commands?
kkremitzki
Postby kkremitzki » Sat Mar 11, 2017 10:02 pm
There are two commands in the toolbar which I suspect are holdouts from a previous workflow:
  • View sketch perpendicular to sketch plane
  • Close the editing of the sketch
I'm assuming they're unused, so I made a branch which removes them and adds a useful Sketcher command, to edit the selected sketch object.
https://github.com/FreeCAD/FreeCAD/comp ... 2?expand=1
Is this OK for a PR?
ian.rees
Re: Unused Sketcher commands?
Postby ian.rees » Sun Mar 12, 2017 6:43 am
kkremitzki wrote:[*] View sketch perpendicular to sketch plane
I find this one quite handy - it's really easy to end up with the sketch in a funny orientation in the 3D view, this button gets it right back where it should be.
In general, I think if you're going to remove a command like this, that the code that implements it should also go away (in this case, see src/Mod/Sketcher/Gui/Command.cpp ) . Otherwise we end up with a bunch of dead code that sucks resources (mainly meaning development effort). -Ian-
ickby
Postby ickby » Sun Mar 12, 2017 6:58 am
Yes, good idea to remove those. They seem to have been forgotten.
@ianrees: Those command will ony be removed from PartDesign, where you cant use them anyway. When editing a sketch FreeCAD changes to the sketcher workbench where they are still available.
ian.rees
Postby ian.rees » Sun Mar 12, 2017 7:02 am
Ahh, got it, thanks! -Ian-
