Polar pattern bugs
- kkremitzki
Polar pattern bugs
The following issues in the tracker all seem to be duplicates of the same issue that is present in 0.16, but fixed in 0.17. All sample files in the issues can be PartDesign->Migrate'd, and afterwards the steps to reproduce no longer produce the issue. Can these be closed as fixed in 0.17?
#2028
#2637
#2246
#2072
#2248
#2028
#2637
#2246
#2072
#2248
- DeepSOIC
Re: Polar pattern bugs
I think yes!
I'm sorry guys, I know it's fun to close issues, but it seems I need to play the part of the buzzkill again.
On what basis can you say that for example issue #2248 is resolved?
No file were attached to this issue. Reading this description:
So I would say this bug is definitely not fixed.
Not only that, but a new bug crept up: I completed the PolarPattern and the feature was created in the tree with no apparent error! But it doesn't work... (there's an error in the Transformed feature messages box while the command is active, but no exclamation point on the PolarPattern icon in the Model tree when the operation is completed)
To see what I mean:
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10611 (Git)
Build type: Unknown
Hash: 44a9ecd25f27ec3efe52c9de9c95ef2b3e19dd17
Python version: 2.7.12
OCC version: 7.1.0
In less than 5 minutes I built a model showing this exact issue in current master.When a polar pattern results in overlap of repetitions, a) if the source feature is a pad, the binary union should be applied between all repetitions and the base solid (if there is one);
To see what I mean:
- Open attached file
- Activate the Body
- Edit PolarPattern
Build type: Unknown
OCC version: 7.1.0
- FC017_issue_2248_Failed_PolarPattern_01.fcstd
- (15.32 KiB) Downloaded 109 times
At least 2248 is fixed where subtractive polar patterns are concerned.
- FC017_issue_2248_Fixed_PolarPattern_02.fcstd
- (36.15 KiB) Downloaded 103 times
- kkremitzki
Thanks for looking at that Normand. The other 4 all had attached files, and the behavior in the bug was no longer occurring. I do see the bug you're describing though with additive polar patterns.
Slightly off-topic, but can anyone explain me why there has to be a major difference between when the angle is 359 deg and when it is 360 deg?
My latest (or last) project: B-spline Construction Project.
I'm sorry, what are you referring to?
Perhaps it is the following, which isn't systematic but comes in handy:
- For degrees < 360 the last object is positioned at the given angle.
Example: degrees = 240, n=3 leads to one objects at 0°, 120° and 240° - For degrees=360 this would lead to two identical objects at the same place (0°=360°). Thus the last object is placed at 360°-1/n*360°
Example: degrees = 360, n=3 leads to the same as before: objects at 0°, 120° and 240°
I break a bit in into this...
The linear pattern have also a bit strange behaviour. When i want create a pattern i know the number of objects and distance between objects.
So every time i use the pattern i am confused by its working method.
So i would say both patterns have strange working behaviour...
- DeepSOIC
+1 for linear pattern. Every time I was using it, I had to try a few times before I got the numbers right.Jee-Bee wrote:The linear pattern have also a bit strange behaviour. When i want create a pattern i know the number of objects and distance between objects. So every time i use the pattern i am confused by its working method.
EDIT: but I have to admit, I hardly ever used partdesign patterns at all. In most cases, Draft arrays are superior and more convenient. And if they are not good enough, I have Lattice.
