Test Request: Part Design Workflow
- DeepSOIC
Re: Test Request: Part Design Workflow
pivy???? It should have been removed from FreeCAD source.... Are you sure you are building the right branch?
oh with log I mean the console output
In the assembly branch it seems there is a little error in the way that the freecad internal pivy source was never deleted. if you set USE_EXTERNAL_PIVY to true in cmake it should compile fine.
EDIT: just checked, the Pivy folder is not completely deleted, maybe an artefact of the rebases, but only few files remain inside. so, as deepsoic suggested, please check if you are on the correct branch: https://github.com/blobfish/FreeCAD_sf_ ... baseMaster
That's why. I read in the first post of the thread "assemblyMergeMaster1" and that's actually what I tried to compile . To avoid future confusion, I suggest modifying the first post.ickby wrote:I would highly value input! And please excuse that I did not rebase the branch on master. Here you find the code:
https://github.com/blobfish/FreeCAD_sf_master branch assemblyMergeMaster1
Best,
CH
