Test Request: Part Design Workflow
- DeepSOIC
Re: Test Request: Part Design Workflow
I'm starting to think that this panel bug might be not rebase-related...
- DeepSOIC
Unfortunately, it is rebase-related. Continuing to bisect...
The primary suspect now is the commit https://github.com/DeepSOIC/FreeCAD-ell ... 8a1a016b45
- DeepSOIC
Suspect verified.
good work, this must have been the mot annoying bisect ever!
- DeepSOIC
This was my first bisect ever
Topology and everything else you mentioned for PartDesign is basically true for Part WB. And ATM PartDesign WB in most use cases is better choice to design parts. Saying current PartDesign WB doesn't work good for the part design purposes but Part WB does basically makes little sense. And i doubt you don't use PartDesign WB to create parts. Parts you later use in Part WB. Unless you basically took the tools from PartDesign workflow and adopted (use) them in Part WB. If you did that you basically turned Part WB in PartDesign WB that does operations on and between parts too.DeepSOIC wrote:I don't understand, what exact problem are you referring to. Is it the link instability problem, which is supposed to be solved by topological naming?triplus wrote:Part WB is affected by the same issues (topology) as PartDesign WB.
Will Body containers in PartDesign WB NEXT erase the conceptual difference any further? I am not yet sure as i will have to use it more to make further conclusions. Anyway this is off topic but i do believe making general conclusion and saying current Part WB is better in designing parts compared to PartDesign WB makes little sense.
- DeepSOIC
Thanks to Fat-Zer efforts, the branch rebases to master without conflicts so far. I rebased it today, it was a breeze: AMM-oldWokrflow6-rebaseMaster
There is no random color functionality in right click context menu anymore.
Thanks DeepSoic, I'd lost track of which branch to followDeepSOIC wrote:Thanks to Fat-Zer efforts, the branch rebases to master without conflicts so far. I rebased it today, it was a breeze: AMM-oldWokrflow6-rebaseMaster
Some win builds:PartDesignNext_win
Sorry for the delay, you got me with "oldWokrflow"
"fight the good fight"
I am trying to test this, but I find myself in build problems.
Please feel free to move this to the "Install / Compile" if not appropriate here
Running this on updated Arch. With Boost 1.58.0
Normaly when building branches other than Master i reuse the AUR:frecad-git PKGBUILD and change the github link to the branch in question. This is not working for me at the moment(guessing having to do with the git name of the repo FreeCAD-ellipse compared to normal freecad) so I am now trying to build this branch the normal way.
Building out of tree with:
Output of cmake
As you can see here the Boost libraries are found.
Output when make fails:
Only thing I could imagine happening is that some deprecated Boost functions has been removed, and my boost version is to new for FreeCAD at the moment.
Please, if someone could shed some light on this, and put me on the right track. I would be very
cmake ../FreeCAD-ellipse/ -DCMAKE_INSTALL_PREFIX:PATH="/usr/lib/freecad" -DCMAKE_INSTALL_DOCDIR:PATH="/usr/share/freecad/doc" -DCMAKE_INSTALL_DATADIR:PATH="/usr/share/freecad" -DCMAKE_INSTALL_LIBDIR:PATH="lib/" -DOCC_INCLUDE_DIR:PATH=/opt/opencascade/inc/ -DPYTHON_EXECUTABLE:FILEPATH=/usr/bin/python2 -DPYSIDEUIC4BINARY:FILEPATH=/usr/bin/python2-pyside-uic -DFREECAD_USE_EXTERNAL_PIVY:BOOL=ON
-- prefix: /usr/lib/freecad
-- datadir: /usr/share/freecad
-- docdir: /usr/share/freecad/doc
-- includedir: include
-- libdir: /usr/lib/freecad/lib
-- Boost version: 1.58.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- signals
-- system
-- thread
-- Found Xerces-C: /usr/lib64/libxerces-c.so
-- PyCXX found:
-- Headers: /home/kjetil/src/tt/FreeCAD-ellipse/src
-- Sources: /home/kjetil/src/tt/FreeCAD-ellipse/src/CXX
-- Check for OCC version >= 0x060703
-- Performing Test OCC_MIN_VERSION
-- Performing Test OCC_MIN_VERSION - Success
-- OpenCASCADE include directory:
-- OpenCASCADE shared libraries directory:
-- checking for module 'openni-dev'
-- package 'openni-dev' not found
-- Could NOT find openni (missing: OPENNI_INCLUDE_DIRS)
-- checking for module 'openni2-dev'
-- package 'openni2-dev' not found
-- Found OpenNI2: /usr/lib64/libOpenNI2.so
-- libshiboken built for Release
-- matplotlib-1.4.3 has been found.
-- Platform is 64-bit, set -D_OCC64
-- Build type:
git
/home/kjetil/src/tt/fcbuild/src/Build/Version.h written
-- Coin3D doc is installed
-- Tag file: /usr/share/doc/coin/html/coin.tag
-- Configuring done
-- Generating done
-- Build files have been written to: /home/kjetil/src/tt/fcbuild
[ 37%] Linking CXX shared library ../../lib/libFreeCADGui.so
[ 38%] Built target FreeCADGui
Scanning dependencies of target FreeCADGuiPy
[ 38%] Building CXX object src/Main/CMakeFiles/FreeCADGuiPy.dir/FreeCADGuiPy.cpp.o
[ 38%] Linking CXX shared library ../../lib/FreeCADGui.so
[ 38%] Built target FreeCADGuiPy
Scanning dependencies of target FreeCADMain
[ 38%] Building CXX object src/Main/CMakeFiles/FreeCADMain.dir/MainGui.cpp.o
[ 38%] Linking CXX executable ../../bin/FreeCAD
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::options_description::m_default_line_length'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::detail::cmdline::set_positional_options(boost::program_options::positional_options_description const&)'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::detail::signal_base::~signal_base()'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::connection::~connection()'
../../lib/libFreeCADApp.so: undefined reference to `typeinfo for boost::program_options::error_with_option_name'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::detail::call_notification::~call_notification()'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::error_with_option_name::what() const'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::detail::signal_base::signal_base(boost::function2<bool, boost::signals::detail::stored_group, boost::signals::detail::stored_group> const&, boost::any const&)'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::connection::disconnect() const'
../../lib/libFreeCADApp.so: undefined reference to `vtable for boost::program_options::variables_map'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::detail::cmdline::cmdline(std::vector<std::string, std::allocator<std::string> > const&)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::detail::cmdline::set_additional_parser(boost::function1<std::pair<std::string, std::string>, std::string const&>)'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::detail::call_notification::call_notification(boost::shared_ptr<boost::signals::detail::signal_base_impl> const&)'
../../lib/libFreeCADApp.so: undefined reference to `vtable for boost::program_options::value_semantic_codecvt_helper<char>'
../../lib/libFreeCADApp.so: undefined reference to `typeinfo for boost::program_options::value_semantic_codecvt_helper<char>'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::validation_error::get_template(boost::program_options::validation_error::kind_t)'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::detail::named_slot_map::begin()'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::notify(boost::program_options::variables_map&)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::options_description_easy_init::operator()(char const*, char const*)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::options_description_easy_init::operator()(char const*, boost::program_options::value_semantic const*, char const*)'
../../lib/libFreeCADApp.so: undefined reference to `boost::basic_regex<char, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::do_assign(char const*, char const*, unsigned int)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::validators::check_first_occurrence(boost::any const&)'
../../lib/libFreeCADApp.so: undefined reference to `boost::re_detail::perl_matcher<__gnu_cxx::__normal_iterator<char const*, std::string>, std::allocator<boost::sub_match<__gnu_cxx::__normal_iterator<char const*, std::string> > >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::find()'
../../lib/libFreeCADApp.so: undefined reference to `boost::re_detail::perl_matcher<char const*, std::allocator<boost::sub_match<char const*> >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::match()'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::abstract_variables_map::operator[](std::string const&) const'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::error_with_option_name::substitute_placeholders(std::string const&) const'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::value_semantic_codecvt_helper<char>::parse(boost::any&, std::vector<std::string, std::allocator<std::string> > const&, bool) const'
../../lib/libFreeCADApp.so: undefined reference to `vtable for boost::program_options::error_with_option_name'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::variables_map::variables_map()'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::detail::named_slot_map::end()'
../../lib/libFreeCADApp.so: undefined reference to `typeinfo for boost::regex_error'
../../lib/libFreeCADApp.so: undefined reference to `boost::re_detail::perl_matcher<char const*, std::allocator<boost::sub_match<char const*> >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::construct_init(boost::basic_regex<char, boost::regex_traits<char, boost::cpp_regex_traits<char> > > const&, boost::regex_constants::_match_flags)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::positional_options_description::positional_options_description()'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::invalid_option_value::invalid_option_value(std::string const&)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::positional_options_description::add(char const*, int)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::basic_parsed_options<char> boost::program_options::parse_config_file<char>(std::basic_istream<char, std::char_traits<char> >&, boost::program_options::options_description const&, bool)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::operator<<(std::ostream&, boost::program_options::options_description const&)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::detail::cmdline::get_canonical_option_prefix()'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::options_description::add(boost::program_options::options_description const&)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::arg'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::detail::signal_base_impl::connect_slot(boost::any const&, boost::signals::detail::stored_group const&, boost::shared_ptr<boost::signals::detail::slot_base::data_t>, boost::signals::connect_position)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::options_description::options_description(std::string const&, unsigned int, unsigned int)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::detail::cmdline::set_options_description(boost::program_options::options_description const&)'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::detail::slot_base::create_connection()'
../../lib/libFreeCADApp.so: undefined reference to `boost::re_detail::perl_matcher<__gnu_cxx::__normal_iterator<char const*, std::string>, std::allocator<boost::sub_match<__gnu_cxx::__normal_iterator<char const*, std::string> > >, boost::regex_traits<char, boost::cpp_regex_traits<char> > >::construct_init(boost::basic_regex<char, boost::regex_traits<char, boost::cpp_regex_traits<char> > > const&, boost::regex_constants::_match_flags)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::validate(boost::any&, std::vector<std::string, std::allocator<std::string> > const&, std::string*, int)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::store(boost::program_options::basic_parsed_options<char> const&, boost::program_options::variables_map&, bool)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::to_internal(std::string const&)'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::connection::operator=(boost::signals::connection const&)'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::options_description::add_options()'
../../lib/libFreeCADGui.so: undefined reference to `boost::signals::trackable::~trackable()'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::detail::cmdline::run()'
../../lib/libFreeCADApp.so: undefined reference to `boost::program_options::error_with_option_name::error_with_option_name(std::string const&, std::string const&, std::string const&, int)'
src/Main/CMakeFiles/FreeCADMain.dir/build.make:120: recipe for target 'bin/FreeCAD' failed
make[2]: *** [bin/FreeCAD] Error 1
CMakeFiles/Makefile2:828: recipe for target 'src/Main/CMakeFiles/FreeCADMain.dir/all' failed
make[1]: *** [src/Main/CMakeFiles/FreeCADMain.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
