ickby wrote:unfortunatly I don't realy have time the next weeks to check your changes.
sure, no hurry here... anyway it's not finished yet...
ickby wrote:One thought I had recently: you may want to pull in the changes I've done in my branch, as it will get only more complicated with more large changes in your branch.
I was gonna to propose to merge after Part changes... except by the Plane's view provider's selection stuff, which I was gonna to cherry-pick sooner...
DeepSOIC wrote:Some time back, there were two options to attach sketches to planes. The selection was done by adding "front"/"back" subelement into the reference's subelement field. At some point I decided to remove that, because I've added a reversal property. That's what the assert is about - when attaching to planes, subelement is expected to be empty. You can kill that assert if you want to.
Thanks, I've run into those several times because Plain's view provider returns "Main" sometimes, so I'll just remove them...
