DOFS in Assembly mode
Jee-Bee
Post by Jee-Bee »
I Just installed the assembly 2 plugin.
I tried it and i found out that when i add a plane constraints on 2 (circular) surfaces the 2 surfaces are locked/fully constraint with each other.
In my opinion i have at least 3 DOFS to do. 2 directions and 1 rotation. FreeCAD doesn't know where i want place my planes...
Will this change in the the final assembly WB? or is this still the same
I have added my test assy as attachment
Test_assy_assembly_2.FCStd
(4.67 KiB) Downloaded 113 times
triplus
Re: DOFS in Assembly mode
Post by triplus »
Jee-Bee wrote:I Just installed the assembly 2 plugin.
Assembly2 is 3rd Party module and if the forum would have this section this question would belong there. Therefore this isn't the Assembly module in development that will eventually be merged in FreeCAD.
As for your question. If you click on animate degrees of freedom button you can see remaining and expected 3 degrees of freedom are detected and after you can animate them.
Jee-Bee
Post by Jee-Bee »
triplus wrote:Assembly2 is 3rd Party module and if the forum would have this section this question would belong there. Therefore this isn't the Assembly module in development that will eventually be merged in FreeCAD.
Sorry Just curious about the difference between the 3th party module and the real one
triplus
Post by triplus »
Both are real modules but 3rd Party modules aren't included in FreeCAD code and are developed separately by 3rd Party developers.
Roland
Post by Roland »
Where might I find the 1st party assembly wb?
sgrogan
Post by sgrogan »
Roland wrote:Where might I find the 1st party assembly wb?
See here if intersted:viewtopic.php?f=20&t=11662#p93731
But it's not in a working state.
"fight the good fight"
