Compile error: Document.cpp
hinckel
Post by hinckel »
/home/hinckel/FreeCAD/JRFreeCAD/src/App/Document.cpp: In member function ‘std::vector<App::DocumentObject*> App::Document::findObjects(const Base::Type&, const char*) const’:
/home/hinckel/FreeCAD/JRFreeCAD/src/App/Document.cpp:2084:5: error: ‘regex’ is not a member of ‘boost’
boost::regex rx(objname);
/home/hinckel/FreeCAD/JRFreeCAD/src/App/Document.cpp:2084:18: error: expected ‘;’ before ‘rx’
/home/hinckel/FreeCAD/JRFreeCAD/src/App/Document.cpp:2085:5: error: ‘cmatch’ is not a member of ‘boost’
boost::cmatch what;
/home/hinckel/FreeCAD/JRFreeCAD/src/App/Document.cpp:2085:19: error: expected ‘;’ before ‘what’
boost::cmatch what;
/home/hinckel/FreeCAD/JRFreeCAD/src/App/Document.cpp:2089:17: error: ‘regex_match’ is not a member of ‘boost’
if (boost::regex_match((*it)->getNameInDocument(), what, rx))
/home/hinckel/FreeCAD/JRFreeCAD/src/App/Document.cpp:2089:64: error: ‘what’ was not declared in this scope
/home/hinckel/FreeCAD/JRFreeCAD/src/App/Document.cpp:2089:70: error: ‘rx’ was not declared in this scope
cmake log
hinckel@sigma:~/FreeCAD/JRFreeCAD-Build> cmake ../JRFreeCAD
-- prefix: /usr/local
-- datadir: data
-- docdir: doc
-- includedir: include
-- libdir: /usr/local/lib
-- Boost version: 1.59.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- signals
-- system
-- thread
-- Found Xerces-C: /usr/lib64/libxerces-c.so
-- PyCXX found:
-- Headers: /home/hinckel/FreeCAD/JRFreeCAD/src
-- Sources: /home/hinckel/FreeCAD/JRFreeCAD/src/CXX
-- -- OpenCASCADE Community Edition has been found.
-- -- Found OCE/OpenCASCADE version: 6.8.0
-- -- OCE/OpenCASCADE include directory: /usr/local/lib/oce-0.17-dev/../../include/oce
-- -- OCE/OpenCASCADE shared libraries directory:
-- libshiboken built for Debug
-- Found PySide Tools: /usr/bin/pyside-uic, /usr/bin/pyside-rcc
-- -- matplotlib-1.4.3 has been found.
-- Platform is 64-bit, set -D_OCC64
-- Build type:
Founder
Re: Compile error: Document.cpp
Post by wmayer »
You must install the boost regex-dev package.
hinckel
Post by hinckel »
From my search boost regex-dev is not part of standard boost distribution. Found a package for Ubuntu. Could not find a suitable
rpm package. (I am using openSUSE).
Thanks
J N Hinckel
hinckel
Post by hinckel »
To be sure:
This problem occurs only with the dev-assembly-next branch
I have no problem compiling the master branch of the git repo.
kcleung
Post by kcleung »
I am running lubuntu 15.10 with cmake-3.2 and have both libboost-regex1.58-dev and libboost-regex1.58.0 installed.
However when I run make, it fails exactly the same way.
I have just found out the reason:
In src/App/Document.cpp, the inclusion of boost/regex.cpp is encapsulated in a conditional block:
#if USE_OLD_DAG
# include <boost/graph/topological_sort.hpp>
# include <boost/graph/depth_first_search.hpp>
# include <boost/graph/dijkstra_shortest_paths.hpp>
# include <boost/graph/visitors.hpp>
# include <boost/graph/graphviz.hpp>
# include <boost/bind.hpp>
# include <boost/regex.hpp>
# include <boost/unordered_set.hpp>
#endif //USE_OLD_DAG
However, the method at line 2086 that uses boost::regex:
std::vector<DocumentObject*> Document::findObjects(const Base::Type& typeId, const char* objname) const
boost::cmatch what;
std::vector<DocumentObject*> Objects;
for (std::vector<DocumentObject*>::const_iterator it = d->objectArray.begin(); it != d->objectArray.end(); ++it) {
if ((*it)->getTypeId().isDerivedFrom(typeId)) {
Objects.push_back(*it);
return Objects;
is not included in the conditional block that uses the same USE_OLD_DAG flag, and therefore it is always included.
Therefore whenever USE_OLD_DAG is false, the system will fail to include the boost/regex.hpp header and the compilation will ultimate fail. Here I suspect some merge problems.
jriegel: Could you please check whether there are any merge problems?
