Test request
ickby
Re: Test request
Postby ickby » Wed Oct 30, 2013 4:32 pm
Oh compiler errors, I thought you had runtime errors? Best is to post a full log of all compiler errors, maybe via pastebin. And if you also have runtime errors, then please give a full log of the freecad internal python console here too.
The problem you mentioned here (setPlaceholder) is due to a old qt version in libpack which does not support placeholder texts. I pushed a fix to my github repository.
dre99gsx
Re: Test request
Postby dre99gsx » Wed Oct 30, 2013 5:05 pm
I'm getting both compile errors and run time errors. If the compile errors are causing the runtime (assumption), then I should fix these first. I thought I had the latest lib pack:
freecadlibs_8.1_x86_vc9
Looks like it includes Qt 4.5.2
If there is a newer lib pack, please advise.
I am not able to upload attachments for some reason, and the entire build log is too large to paste. Here is just the assembly portion:
Build started: Project: AssemblyGui, Configuration: Release|Win32
 Command Lines      Creating temporary file "c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\RSP00031B54447160.rsp" with contents
/O2 /Ob2 /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include" /I "C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src" /I "C:\Program Files\Git\bin\FreeCAD_constraint-assembly\src" /I "C:\Program Files\Git\bin\FreeCAD_constraint-assembly\src\Mod\Assembly\App" /I "C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\zlib" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\OpenCascade" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\Qt" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtCore" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtGui" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtDesigner" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtSvg" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtNetwork" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtSql" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtTest" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtUiTools" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtXml" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtOpenGl" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\QT\QtWebKit" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\coin" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\soqt" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\python" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\xercesc" /I "C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\eigen3" /D "WIN32" /D "_WINDOWS" /D "NDEBUG" /D "HAVE_ACOSH" /D "HAVE_ASINH" /D "HAVE_ATANH" /D "CMAKE_INTDIR=\"Release\"" /D "AssemblyGui_EXPORTS" /D "_WINDLL" /D "_MBCS" /FD /EHsc /MD /Fo"AssemblyGui.dir\Release\\" /Fd"AssemblyGui.dir\Release\vc90.pdb" /W3 /c /TP "..\..\..\..\..\src\Mod\Assembly\Gui\Workbench.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\PreCompiled.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\CommandConstraints.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\Command.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\AppAssemblyGuiPy.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\AppAssemblyGui.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\TaskAssemblyConstraints.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\TaskDlgAssemblyConstraints.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\ViewProviderConstraintGroup.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\ViewProviderConstraint.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\ViewProviderAssembly.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\ViewProviderPart.cpp"
"..\..\..\..\..\src\Mod\Assembly\Gui\ViewProvider.cpp"
".\qrc_Assembly.cxx"
Creating command line "cl.exe @"c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\RSP00031B54447160.rsp" /nologo /errorReport:prompt"
 Output Window      Compiling...
Workbench.cpp
PreCompiled.cpp
c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\core\equations.hpp(387) : warning C4522: 'dcm::Distance' : multiple assignment operators specified
c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\core\equations.hpp(453) : warning C4522: 'dcm::Orientation' : multiple assignment operators specified
c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\core\equations.hpp(519) : warning C4522: 'dcm::Angle' : multiple assignment operators specified
c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\module3d/coincident.hpp(92) : warning C4522: 'dcm::details::ci_orientation' : multiple assignment operators specified
c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\module3d/coincident.hpp(249) : warning C4522: 'dcm::details::ci_distance' : multiple assignment operators specified
c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\module3d/alignment.hpp(93) : warning C4522: 'dcm::details::al_orientation' : multiple assignment operators specified
C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\ui_TaskAssemblyConstraints.h(419) : error C2039: 'setPlaceholderText' : is not a member of 'QLineEdit'
        c:\freecad\freecadlibs_8.1_x86_vc9\include\qt\qtgui\../../src/gui/widgets/qlineedit.h(64) : see declaration of 'QLineEdit'
C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\ui_TaskAssemblyConstraints.h(427) : error C2039: 'setPlaceholderText' : is not a member of 'QLineEdit'
Command.cpp
AppAssemblyGui.cpp
C:\Program Files\Git\bin\FreeCAD_constraint-assembly\src\Mod\Assembly\App\opendcm/core/equations.hpp(387) : warning C4522: 'dcm::Distance' : multiple assignment operators specified
C:\Program Files\Git\bin\FreeCAD_constraint-assembly\src\Mod\Assembly\App\opendcm/core/equations.hpp(453) : warning C4522: 'dcm::Orientation' : multiple assignment operators specified
C:\Program Files\Git\bin\FreeCAD_constraint-assembly\src\Mod\Assembly\App\opendcm/core/equations.hpp(519) : warning C4522: 'dcm::Angle' : multiple assignment operators specified
ViewProvider.cpp
qrc_Assembly.cxx
Generating Code...
 Results      Build log was saved at "file://c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BuildLog.htm"
AssemblyGui - 8 error(s), 60 warning(s)
ickby
Re: Test request
Postby ickby » Wed Oct 30, 2013 5:25 pm
Thanks for the log, that is really helpful. I'm developing on linux, so I don't use libpack (your libpack version is fine). The error should be fixed now. The warnings are not a problem, I will treat the "multiple assignment operators specified" massages later. Please try with the updated source code again.
dre99gsx
Re: Test request
Postby dre99gsx » Wed Oct 30, 2013 7:22 pm
Left with 2 errors during compile. Looks like linker issues. I do apologize if I'm doing something wrong here...
Also, when I try to run it and create New, then change workspace to "Assembly", I get this error:
"matplotlib not found, Plot module will be disabled
No module named AssemblyGui"
Python 2.6.2 (r262:71600, Jun 22 2009, 21:44:05) [MSC v.1500 32 bit (Intel)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> import WebGui
>>> from StartPage import StartPage
>>> WebGui.openBrowserHTML(StartPage.handle(),App.getResourceDir() + 'Mod/Start/StartPage/','Start page')
>>> App.newDocument()
>>> App.setActiveDocument("Unnamed")
>>> App.ActiveDocument=App.getDocument("Unnamed")
>>> Gui.ActiveDocument=Gui.getDocument("Unnamed")
>>> Gui.activateWorkbench("AssemblyWorkbench")
Obviously, the gui files are missing from /Mod directory. I think the other constraint errors were caused by me copying the Gui files over from a previous build.
So for background, I use CMake2.8 to create the VStudio2009 solution, linking to the proper libraries (I basically followed the instructions outlined in the tutorial link provided before).
Build log below:
Build Log      Build started: Project: AssemblyGui, Configuration: Release|Win32
 Command Lines      Creating temporary file "c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001E148688444.bat" with contents
@echo off
C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\bin\rcc.exe -name Assembly -o "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/Build/src/Mod/Assembly/Gui/qrc_Assembly.cxx" "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/src/Mod/Assembly/Gui/Resources/Assembly.qrc"
if errorlevel 1 goto :VCReportError
if errorlevel 1 goto VCReportError
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from "Generating qrc_Assembly.cxx"
exit 1
:VCEnd
Creating command line """c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001E148688444.bat"""
Creating temporary file "c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001E548688444.bat" with contents
@echo off
C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\bin\moc.exe -DBOOST_TT_HAS_OPERATOR_HPP_INCLUDED "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/src/Mod/Assembly/Gui/TaskAssemblyConstraints.h" -o "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/Build/src/Mod/Assembly/Gui/moc_TaskAssemblyConstraints.cpp"
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from "Generating moc_TaskAssemblyConstraints.cpp"
exit 1
:VCEnd
Creating command line """c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001E548688444.bat"""
Creating temporary file "c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001E748688444.bat" with contents
@echo off
C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\bin\moc.exe -DBOOST_TT_HAS_OPERATOR_HPP_INCLUDED "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/src/Mod/Assembly/Gui/TaskDlgAssemblyConstraints.h" -o "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/Build/src/Mod/Assembly/Gui/moc_TaskDlgAssemblyConstraints.cpp"
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from "Generating moc_TaskDlgAssemblyConstraints.cpp"
exit 1
:VCEnd
Creating command line """c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001E748688444.bat"""
Creating temporary file "c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001E948688444.bat" with contents
@echo off
"C:\Program Files\CMake 2.8\bin\cmake.exe" -E copy "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/src/Mod/Assembly/InitGui.py" "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/Build/Mod/Assembly/InitGui.py"
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from "Generating ../../../../Mod/Assembly/InitGui.py"
exit 1
:VCEnd
Creating command line """c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001E948688444.bat"""
Creating temporary file "c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001EC48688444.bat" with contents
@echo off
C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\bin\uic.exe -o "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/Build/src/Mod/Assembly/Gui/ui_TaskAssemblyConstraints.h" "C:/Program Files/Git/bin/FreeCAD_constraint-assembly/src/Mod/Assembly/Gui/TaskAssemblyConstraints.ui"
goto VCEnd
:VCReportError
echo Project : error PRJ0019: A tool returned an error code from "Generating ui_TaskAssemblyConstraints.h"
exit 1
:VCEnd
Creating command line """c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\BAT0001EC48688444.bat"""
Creating temporary file "c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\RSP0001F748688444.rsp" with contents
Creating command line "cl.exe @"c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\RSP0001F748688444.rsp" /nologo /errorReport:prompt"
Creating temporary file "c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\RSP00022948688444.rsp" with contents
/OUT:"C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\Mod\Assembly\Release\..\AssemblyGui.pyd" /VERSION:0.0 /INCREMENTAL:NO /LIBPATH:"C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\lib\Release" /LIBPATH:"C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\lib" /DLL /MANIFEST /MANIFESTFILE:"AssemblyGui.dir\Release\AssemblyGui.pyd.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /NODEFAULTLIB /PDB:"C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\Mod\Assembly\Release\..\AssemblyGui.pdb" /DYNAMICBASE /NXCOMPAT /IMPLIB:"C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\Release\AssemblyGui.lib"  /machine:X86 /LARGEADDRESSAWARE kernel32.lib user32.lib gdi32.lib winspool.lib SHFolder.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib  ..\App\Release\Assembly.lib ..\..\Part\Gui\Release\PartGui.lib ..\..\..\Gui\Release\FreeCADGui.lib coin3.lib soqt1.lib QtGui4.lib QtDesigner4.lib QtSvg4.lib QtNetwork4.lib QtSql4.lib QtTest4.lib QtXml4.lib QtOpenGl4.lib QtWebKit4.lib QtUiTools.lib opengl32.lib glu32.lib ..\..\Part\App\Release\Part.lib TKFillet.lib TKMesh.lib TKernel.lib TKG2d.lib TKG3d.lib TKMath.lib TKIGES.lib TKSTL.lib TKShHealing.lib TKXSBase.lib TKBool.lib TKXSBase.lib TKBool.lib TKBO.lib TKBRep.lib TKTopAlgo.lib TKGeomAlgo.lib TKGeomBase.lib TKOffset.lib TKPrim.lib TKSTEP.lib TKSTEPBase.lib TKSTEPAttr.lib TKHLR.lib TKFeat.lib ..\..\..\App\Release\FreeCADApp.lib ..\..\..\Base\Release\FreeCADBase.lib boost_filesystem-vc90-mt-1_48.lib boost_system-vc90-mt-1_48.lib boost_graph-vc90-mt-1_48.lib boost_program_options-vc90-mt-1_48.lib boost_regex-vc90-mt-1_48.lib boost_signals-vc90-mt-1_48.lib boost_thread-vc90-mt-1_48.lib python26.lib xerces-c_2.lib QtCore4.lib zdll.lib MSVCRT.lib MSVCPRT.lib Rpcrt4.lib
".\AssemblyGui.dir\Release\qrc_Assembly.obj"
".\AssemblyGui.dir\Release\ViewProvider.obj"
".\AssemblyGui.dir\Release\ViewProviderPart.obj"
".\AssemblyGui.dir\Release\ViewProviderAssembly.obj"
".\AssemblyGui.dir\Release\ViewProviderConstraint.obj"
".\AssemblyGui.dir\Release\ViewProviderConstraintGroup.obj"
".\AssemblyGui.dir\Release\TaskDlgAssemblyConstraints.obj"
".\AssemblyGui.dir\Release\TaskAssemblyConstraints.obj"
".\AssemblyGui.dir\Release\AppAssemblyGui.obj"
".\AssemblyGui.dir\Release\AppAssemblyGuiPy.obj"
".\AssemblyGui.dir\Release\Command.obj"
".\AssemblyGui.dir\Release\CommandConstraints.obj"
".\AssemblyGui.dir\Release\PreCompiled.obj"
".\AssemblyGui.dir\Release\Workbench.obj"
Creating command line "link.exe @"c:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\AssemblyGui.dir\Release\RSP00022948688444.rsp" /NOLOGO /ERRORREPORT:PROMPT"
 Output Window      Generating qrc_Assembly.cxx
Compiling...
Workbench.cpp
PreCompiled.cpp
Command.cpp
AppAssemblyGui.cpp
C:\Program Files\Microsoft Visual Studio 9.0\VC\include\xtree(606) : warning C4503: 'std::allocator<_Ty>::rebind<_Other>' : decorated name length exceeded, name was truncated
        with
            _Ty=std::pair,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>>>
        and
            _Other=std::_Tree_nod,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>>,std::less,std::allocator,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>>>>,false>>::_Node
        C:\Program Files\Microsoft Visual Studio 9.0\VC\include\xtree(605) : while compiling class template member function 'unsigned int std::_Tree<_Traits>::max_size(void) const'
        with
            _Traits=std::_Tmap_traits,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>>,std::less,std::allocator,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>>>>,false>
        C:\Program Files\Microsoft Visual Studio 9.0\VC\include\map(78) : see reference to class template instantiation 'std::_Tree<_Traits>' being compiled
        with
        c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm/core/clustergraph.hpp(446) : see reference to class template instantiation 'std::map<_Kty,_Ty>' being compiled
        with
            _Kty=dcm::LocalVertex,
            _Ty=boost::shared_ptr,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>>
        c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\module3d\solver.hpp(292) : see reference to class template instantiation 'dcm::ClusterGraph' being compiled
        with
            edge_prop=boost::mpl::vector1,
            vertex_prop=boost::mpl::vector1,
            cluster_prop=boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,
            objects=boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>
        c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\module3d\solver.hpp(288) : while compiling class template member function 'void dcm::details::SystemSolver::solveCluster(boost::shared_ptr,Sys &)'
        with
            Sys=Solver,
            T=dcm::ClusterGraph,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>
        c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\module3d\solver.hpp(283) : while compiling class template member function 'void dcm::details::SystemSolver::execute(Sys &)'
        with
            Sys=Solver
        c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\module3d/module.hpp(219) : see reference to class template instantiation 'dcm::details::SystemSolver' being compiled
        with
            Sys=Solver
        ..\..\..\..\..\src\Mod\Assembly\Gui\TaskAssemblyConstraints.cpp(552) : see reference to class template instantiation 'dcm::Module3D::type::Geometry3D' being compiled
        with
            Typelist=boost::mpl::vector4,
            ID=std::string,
            Sys=Solver
        with
        and
C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(470) : warning C4503: 'std::_Allocator_base<_Ty>' : decorated name length exceeded, name was truncated
        with
            _Ty=VertexInfo
        C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(468) : while compiling class template member function 'std::vector<_Ty>::vector(void)'
        with
            _Ty=VertexInfo
        C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\boost/graph/undirected_dfs.hpp(50) : see reference to class template instantiation 'std::vector<_Ty>' being compiled
        with
            _Ty=VertexInfo
        C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\boost/graph/undirected_dfs.hpp(152) : see reference to function template instantiation 'void boost::detail::undir_dfv_impl(const IncidenceGraph &,void *,DFSVisitor &,VertexColorMap,EdgeColorMap)' being compiled
        with
            Graph=dcm::ClusterGraph,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>,
            DFSVisitor=dcm::details::SystemSolver::cycle_dedector,
            VertexColorMap=C,
            EdgeColorMap=boost::associative_property_map,
            IncidenceGraph=dcm::ClusterGraph,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>
        C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\boost/graph/undirected_dfs.hpp(185) : see reference to function template instantiation 'void boost::undirected_dfs(const Graph &,DFSVisitor,VertexColorMap,EdgeColorMap,Vertex)' being compiled
        with
            VertexColorMap=C,
            Vertex=void *
        C:\FreeCAD\FreeCADLibs_8.1_x86_VC9\include\boost/graph/undirected_dfs.hpp(232) : see reference to function template instantiation 'void boost::detail::udfs_dispatch::apply::cycle_dedector,boost::associative_property_map,boost::associative_property_map,boost::edge_color_t,boost::bgl_named_params>(const Graph &,DFSVisitor,Vertex,const boost::bgl_named_params,boost::edge_color_t,boost::bgl_named_params> &,EdgeColorMap,VertexColorMap)' being compiled
        with
            VertexColorMap=C,
            Sys=Solver,
            UniquePairAssociativeContainer=ecmap,
            T=boost::associative_property_map,
            Tag=boost::vertex_color_t,
            Base=boost::bgl_named_params,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>>,boost::vertex_index_t,boost::bgl_named_params::cycle_dedector,boost::graph_visitor_t,boost::no_property>>,
            Vertex=void *,
        c:\program files\git\bin\freecad_constraint-assembly\src\mod\assembly\app\opendcm\module3d\solver.hpp(421) : see reference to function template instantiation 'void boost::undirected_dfs,boost::edge_color_t,boost::bgl_named_params,Tag,Base>>(const Graph &,const boost::bgl_named_params,boost::edge_color_t,boost::bgl_named_params,Tag,Base>> &)' being compiled
        with
            T=dcm::ClusterGraph,boost::mpl::vector1,boost::mpl::vector4,std::string>::type::math_prop,dcm::Module3D,std::string>::type::fix_prop>,boost::mpl::vector3,std::string>::type::Geometry3D,dcm::Module3D,std::string>::type::Constraint3D,dcm::ModulePart,std::string>::type::Part>>,
        with
            _Ty=VertexInfo
C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(470) : warning C4503: 'std::allocator<_Ty>::rebind<_Other>' : decorated name length exceeded, name was truncated
        with
            _Ty=VertexInfo
        and
            _Other=std::_Aux_cont
        with
            _Ty=VertexInfo
        and
            _Other=VertexInfo
C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(470) : warning C4503: 'std::allocator<_Ty>' : decorated name length exceeded, name was truncated
        with
            _Ty=VertexInfo
C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(800) : warning C4503: 'std::_Ranit<_Ty,_Diff,_Pointer,_Reference>' : decorated name length exceeded, name was truncated
        with
            _Ty=VertexInfo,
            _Diff=std::allocator::difference_type,
            _Pointer=const std::pair> ,
            _Reference=const std::pair>
        C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(799) : while compiling class template member function 'std::pair<_Ty1,_Ty2> &std::vector<_Ty>::back(void)'
        with
            _Ty1=Vertex,
            _Ty2=std::pair,
            _Ty=VertexInfo
C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(800) : warning C4503: 'std::_Iterator_with_base<_Category,_Ty,_Diff,_Pointer,_Reference>' : decorated name length exceeded, name was truncated
        with
            _Category=std::random_access_iterator_tag,
            _Ty=VertexInfo,
        with
            _Ty=VertexInfo,
        with
            _Ty=VertexInfo,
C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(800) : warning C4503: 'std::_Vector_const_iterator<_Ty,_Alloc>' : decorated name length exceeded, name was truncated
        with
            _Ty=VertexInfo,
            _Alloc=std::allocator
C:\Program Files\Microsoft Visual Studio 9.0\VC\include\vector(800) : warning C4503: 'std::_Vector_iterator<_Ty,_Alloc>' : decorated name length exceeded, name was truncated
        with
            _Ty=VertexInfo,
ViewProvider.cpp
qrc_Assembly.cxx
Generating Code...
Linking...
   Creating library C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\Release\AssemblyGui.lib and object C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\src\Mod\Assembly\Gui\Release\AssemblyGui.exp
ViewProviderAssembly.obj : error LNK2019: unresolved external symbol "class Assembly::ItemAssembly * ActiveAsmObject" (?ActiveAsmObject@@3PAVItemAssembly@Assembly@@A) referenced in function "public: virtual __thiscall AssemblyGui::ViewProviderItemAssembly::~ViewProviderItemAssembly(void)" (??1ViewProviderItemAssembly@AssemblyGui@@UAE@XZ)
C:\Program Files\Git\bin\FreeCAD_constraint-assembly\Build\Mod\Assembly\Release\..\AssemblyGui.pyd : fatal error LNK1120: 1 unresolved externals
AssemblyGui - 2 error(s), 73 warning(s)
ickby
Re: Test request
Postby ickby » Wed Oct 30, 2013 7:57 pm
hello,
he missing module is due to the compiler errors, the libs are not created. So we first have to treat the compiler errors. I believe I fixed the linker problem (the one at the very end of your report) but to be honest, I have no idea about whats wrong with qt moc. Could you please delete the folder
and recompile? If the same errors occur again I would need to ask some of the windows experts. All the warnings are not critical.
dre99gsx
Re: Test request
Postby dre99gsx » Wed Oct 30, 2013 8:46 pm
Just tried, same issue. You did reduce the errors from 8 to 2, so that is progress :)
ickby
Re: Test request
Postby ickby » Thu Oct 31, 2013 6:22 am
I started to build FreeCAD on a virtual machine over night in VisualStudio2008 and it worked with the latest source. I could not reproduce the errors. However, on a quick test I saw that the assembly task dialog was missing all assembly specific icons, so even if it compiled without error there is something wrong with the qt assembly resource (which is mentioned oin your compiler report as error). Maybe the difference is that I compiled in debug mode, but I don't have much experiance with windows development to say anything for sure.
I will investigate this further tomorrow.
Stefan
Site Admin
Re: Test request
Postby wmayer » Thu Oct 31, 2013 8:14 am
I guess this explains everything. ItemAssembly is a class in the "Assembly" module which is used in "AssemblyGui". Therefore the linker needs the corresponding symbols inside "Assembly". On Linux this is no problem because by default all classes get exported to the library but on Windows you have to do it explicitly. So, to solve this issue write "class AppAssemblyExport ItemAssembly".
gdo35
Re: Test request
Postby gdo35 » Sat Nov 02, 2013 8:59 am
Running ubuntu 13.10, libcoin60 is replaced by libcoin80. Updating CMake.list and cMake/FindCoin3DDoc.cmake, I tried to rebuild but it failed :
Linking CXX shared library ../../../lib/Driver.so
In file included from /home/gdo/Applications/FreeCAD_constraint/src/3rdParty/Pivy-0.5/coin_header_includes.h:145:0,
                 from /home/gdo/Applications/FreeCAD_constraint/src/3rdParty/Pivy-0.5/coin_wrap.cpp:3930:
/usr/include/Inventor/elements/SoGLTexture3EnabledElement.h:36:2: error: #error Deprecated: use SoMultiTextureEnabledElement instead
In file included from /home/gdo/Applications/FreeCAD_constraint/src/3rdParty/Pivy-0.5/coin_header_includes.h:190:0,
/usr/include/Inventor/elements/SoTexture3EnabledElement.h:36:2: error: #error Deprecated: use SoMultiTextureEnabledElement instead
[  2%] [  2%] MatrixPy.xml
BoundBoxPy.xml
                 from /home/gdo/Applications/FreeCAD_constraint/src/3rdParty/Pivy-0.5/soqt_wrap.cpp:3303:
In file included from /home/gdo/Applications/FreeCAD_constraint/src/3rdParty/Pivy-0.5/coin_wrap.cpp:3930:0:
/home/gdo/Applications/FreeCAD_constraint/src/3rdParty/Pivy-0.5/coin_header_includes.h:668:40: fatal error: Inventor/scxml/ScXMLInvoke.h: Aucun fichier ou dossier de ce type
 #include <Inventor/scxml/ScXMLInvoke.h>
compilation terminated.
In file included from /home/gdo/Applications/FreeCAD_constraint/src/3rdParty/Pivy-0.5/soqt_wrap.cpp:3303:0:
As the ubuntu ppa with daily build is available for 13.10, what do I have to change to make this work for me ? (checking FreeCAD/FreeCAD_sf_master on github did not really help me).
Thanks,
gdo
ickby
Re: Test request
Postby ickby » Sat Nov 02, 2013 10:50 am
Freeecad is not yet ported to libcoin80. You need to use the pivy package provided by ubuntu which works with libcoin80. You can set FREECAD USE EXTERNAL PIVY in cmake.
