FEM page title
FEM page title
the title of some FEM pages is too long, it's hard to read, and the cursor does not help see
FEM_BeamCrossSectionDefinition
FEM_ShellThicknessDefinition
FEM_DisplacementConstraint
FEM_RunFrequencyAnalysis
I'm planning to rename pages in this way
FEM Analysis
FEM Solver
FEM Mesh
FEM Material
FEM Section
FEM Thickness
FEM Nodes
FEM Fixed
FEM Displacement
FEM Force
FEM Pressure
FEM Bearing
FEM Gear
FEM Pulley
FEM Start
FEM Frequency
FEM Purge
FEM Show
suggestions for improvement?
Thanks
Renato
FEM Analysis
FEM Solver
FEM Mesh
FEM Material
FEM Section
FEM Thickness
FEM Nodes
FEM Fixed
FEM Displacement
FEM Force
FEM Pressure
FEM Bearing
FEM Gear
FEM Pulley
FEM Start
FEM Frequency
FEM Purge
FEM Show
Thanks
Renato
Re: FEM page title
good idea, find my2cents
FEM Section --> How about --> FEM CrossSection
FEM Frequency --> FEM_RunFrequencyAnalysis --> could be deleted
FEM Start --> stay at FEM_Calculation
FEM Run --> instead FEM_RunCalculiXccx
cheers bernd
BTW: there are some new tools in FEM and there will be even more shortly ...
cheers bernd
Re: FEM page title
@renato:
How about the move of the FEM pages? Will it happen? We need to add some (a lot ) new tools. We would use the new names for them from beginning.
Re: FEM page title
excellentbernd wrote:We need to add some (a lot ) new tools.
Sorry, I devoted my time to the manual.bernd wrote:How about the move of the FEM pages?
After some testing, I must say that I made a mistake.
What causes the problem is not the title, but the "Name" in the template GuiCommand.
I do not know if I'm allowed to change this name, and how. Renato
Re: FEM page title
Yes, you can change the name, but beware that that name is used to get the icon (an icon with the same name), so you might need to re-upload the icon under a new name too.
Basically there is one important rule: the wiki page name must be exactly the command name in FreeCAD. Unfortunately there is no easy way to get the exact command name, other than looking directly into the code (into src/Mod/*WorkbenchName*/InitGui.py for pure python workbenches, or in src/Mod/*Workbenchname*/Gui/Workbench.cpp for C++ and hybrid python/C++ ones.
For example, for FEM, all command names are listed here: https://github.com/FreeCAD/FreeCAD/blob ... kbench.cpp
But that is only for the wiki page name itself. What appears in the Guicommand template could be different, if needed, for ex. to make it easier to understand (for example, add spaces inside the name)
Re: FEM page title
Ahh I did not know about the rule but it makes sense to me!yorik wrote:Basically there is one important rule: the wiki page name must be exactly the command name in FreeCAD. Unfortunately there is no easy way to get the exact command name, other than looking directly into the code (into src/Mod/*WorkbenchName*/InitGui.py for pure python workbenches, or in src/Mod/*Workbenchname*/Gui/Workbench.cpp for C++ and hybrid python/C++ ones.
Renato are you gone rename FEM wiki pages?
Re: FEM page title
ok, this is not a problemyorik wrote:Yes, you can change the name, but beware that that name is used to get the icon (an icon with the same name), so you might need to re-upload the icon under a new name too.
Also ok for thisyorik wrote:Basically there is one important rule: the wiki page name must be exactly the command name in FreeCAD. Unfortunately there is no easy way to get the exact command name, other than looking directly into the code (into src/Mod/*WorkbenchName*/InitGui.py for pure python workbenches, or in src/Mod/*Workbenchname*/Gui/Workbench.cpp for C++ and hybrid python/C++ ones.
Then
- FEM_Analysis that's okay
- FEM_ShellThicknessDefinition must be "Fem_ShellThickness"
- FEM_BeamCrossSectionDefinition must be "Fem_BeamSection"
- ecc...
If this is correct I make the changes.
Re: FEM page title
Donebernd wrote:Renato are you gone rename FEM wiki pages?
Re: FEM page title
cool, much better than before !renatorivo wrote:Donebernd wrote:Renato are you gone rename FEM wiki pages?
Re: FEM page title
Yes exactly.renatorivo wrote:Then
- ecc...
The reason for this is that so these pages are picked by the "What's this?" button in FreeCAD...
