As has already happened in the past, there is a new command that has the name too long, unreadable in the side pane. This with the skin FreeCAD. With the skin vector works.
Change the width of the panel?
Renato
Command name too long in the skin FreeCAD
Re: Command name too long in the skin FreeCAD
Maybe better to change the name of the command... We could make it Arch_Togglesubs or Arch_Toggle_Subcomonent_Display (then we can use spaces instead of _) which do you prefer?
If the interface shows "Toggle Subcomponents", I would say to use Arch_ToggleSubs, or Arch_ToggleSubcomponents, for consistency, but I have no preference.
Here is the preview
Here is the preview
Ok this is done, the command is now renamed to Arch_ToggleSubs.
I already "ordered" the page rename on the wiki but it takes time... After that the command template still needs to be changed, I don't dare to do it during the rename...
