In the Mouse_Model page, http://www.freecadweb.org/wiki/index.ph ... ouse_Model:
1. In the table for Inventor Navigation, second column the text reads "press the left button" but the picture shows the middle button
2. In the intro section on May-Gesture Navigation : "In Maya-Gesture Navigation, all view movements are archived pressing... " should that be activated?
3. What is the text below marked "Obsolete"?
Thanks
~Dimo
Errors in Mouse_Model page?
Re: Errors in Mouse_Model page?
Thanks, Dimo
Obsolete is referred to Scaling, Out of plane shifting, In plane shifting, Rotation, that they do not make more with Clipping plane,
Now, right click on object -> Transform
See obsolete version in https://www.freecadweb.org/wiki/index.p ... ppingPlane
Renato
Manipulating Objects must be rewrittendimo wrote:What is the text below marked "Obsolete"?
Renato
About Transform utility see also https://forum.freecadweb.org/viewtopic.php?f=9&t=17841
Note that the context menu is called "Transform",
in the menu Edit -> is called "Toggle Edit mode",
and the wiki page Std_Edit https://www.freecadweb.org/wiki/index.p ... e=Std_Edit
It would be good if he had always the same name.
Renato
Renato
