Hey Mark,
Cool! I'll have a look at it later, but I suggest you use the TutorialInfo template I created and used on my still unfinished Simple Box Cover tutorial.
Tutorials for Part Design Beginners
Re: Tutorials for Part Design Beginners
Yea, I was looking for that, not your tut, but what it was that moved the index and stuff to the side. Thanks! Next look, let me know if I got that template right.normandc wrote:Hey Mark,
Mark
Edit - I just went back and used the template on my other tutorial, Drawing Template HowTo, so at least my two tut's are conforming to the new standard.
Mark,
I'm checking out freeCAD and I just went through the tutorial you mention here. I found it very helpful and got almost all the way through without issue.
I ran into trouble on the last step, creating a pocket. After sketching the rectangle, I click the pocket tool and get the message "please create a sketch or 2D object first. It must have a support face on a solid." Can you help me understand what's going on here?
Tim
Tim
Hello Tim.tahrenholz wrote: Can you help me understand what's going on here?
Welcome to FreeCAD and the forum.
Which version of FreeCAD are you using ? On which Operating System ?
Read here how to obtain and provide this info.
I am asking because your description sounds like you are running 0.16.6704 which had several bugs and one of them was
a behaviour like you describe. In that case I would recommend de-installing , and downloading and installing of 0.16.6706.
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Roland,
Just installed today. So 16.6706 on Windows 10 64 bit. I started a new project and had the same problem trying to pad a simple figure. But after closing FreeCAD and starting again I no longer have a problem!
FYI
I created the part in 0.16.6706 (including draft dimensions), uploaded it to the github-FreeCAD-Examples-Repo
and added a download-link in the tutorial if someone gets stuck and wants to have a look at the completed file ...
As it happens, I just tried walking through this tutorial last night. I found it better than the previous one (Sketch tutorial) up to where I hit a problem. After beating me up a little for my impertinence, a couple of people noted that I had used construction lines instead of drawing lines. After thinking about this and the fact that the error messages are meaningless to noobs like me, for the most part, and even searching the forum isn't a great option (I ended up on one referring to a circular reference, not the problem at hand), I'm wondering if it would be helpful to have something like a FAQ at the end of a tutorial to list some of the common problems that people experience.
I believe what I did was click on the icon to the right of the one I intended, causing this problem. That might be something that others do too, either at that step or other steps using the same button(s). Dunno, does that sound like something useful? I realize you can never anticipate all the different ways that things can go wrong, but there are some that happen more often than others.
Thanks for your tutorial
+1surferdudemi wrote: ↑Mon Nov 20, 2017 1:03 am I'm wondering if it would be helpful to have something like a FAQ at the end of a tutorial to list some of the common problems that people experience.
