"collision detection", overlapping
just for curiosity: Once someone showed off about "collision detection" in his CAD. Since then I wondered is there is a way in freecad, to say, finding out if two shapes are overlapping?
Maybe there is a (FreeCAD or occ) function near it?
And one might ask, how important would be such "overlapping detection" for an cad-program. Opinions?
Tia
Tia
Re: "collision detection", overlapping
It should be easy, at least in python: Make an intersection and get the volume, this macro could help: http://freecadweb.org/wiki/index.php?title=Macro_FCInfo
Hi!
I've written this brief script that looks for common volumes between shapes and colors them in red:
Select the shapes and copy-paste it, thats all.
Resut:
# JMG 2015
object_list = []
for obj in FreeCAD.Gui.Selection.getSelectionEx():
obj = obj.Object
object_list.append( obj )
for n in range( len(object_list) ):
object_A = object_list[n]
for i in range( len(object_list) ):
if i <= n:
pass
else:
object_B = object_list[i]
common = object_A.Shape.common( object_B.Shape )
if common.Volume > 0.0:
FreeCAD.Console.PrintMessage( '-Intersection- ' + object_A.Name + ' with ' + object_B.Name + '\n')
FreeCAD.Console.PrintMessage( 'Common volume' + str( common.Volume ) + '\n' + '\n' )
intersection_object = FreeCAD.ActiveDocument.addObject( 'Part::Feature' )
intersection_object.Shape = common
intersection_object.ViewObject.ShapeColor = ( 1.0,0.0,0.0,1.0 )
object_A.ViewObject.Transparency = 80
object_B.ViewObject.Transparency = 80
FreeCAD scripts, animations, experiments and more: http://linuxforanengineer.blogspot.com.es/
Open source CNC hot wire cutter project (NiCr): https://github.com/JMG1/NiCr
Exploded Assembly Workbench: https://github.com/JMG1/ExplodedAssembly
hi JMG
if you put your macros (this macro and Text sticker) in "Macros_recipes" they will be more easily accessible
you can request a write permission for the wiki or ask someone to do
mario
mario
hi
it's easier than Python, if you prefer to have visits to your site,
create a page with explanations and one link to download the code on your site
here for permission here Macros_recipes for the table of contents full macros
and ... here for the help ...
mario
mario
Added (@JMG, I hope with your permission) as http://www.freecadweb.org/wiki/index.ph ... ightCommon.
Similarly, also added http://www.freecadweb.org/wiki/index.ph ... Difference.
Cheers,
Gaël
Cheers,
Gaël
Sure, I had this in my TODO list, thanks for doing itAdded (@JMG, I hope with your permission) as
Thanks to all.
aha.
-disttoshape
-common (boolean intersection)
-and another interface in development
well, is it in use, maybe at simulating assemblies, when one piece hits the other, I ask myself? Are there examples for it?
aha.
-disttoshape
