is it possible to temporarily disable preselection in the complete view.
I need this for a script I am working on where preseleciton is obstructive. There it prevents a directly view on highlighted inner faces/edges (see viewtopic.php?f=18&t=12381&p=151950#p151950). A manual workaround is to temporarily set the/all element/s to 'Selectable=False'. I could also set 'Selectable=False' for each object under the mouse cursor by script and restore its original state afterwards but I am sure there has to be a simpler and directer approach .
I found a similar post (viewtopic.php?f=22&t=17684&hilit=preselection) on disabling preselection for specific elements but want avoid this.
Thank you in advance,
HoWil
Temporarily disable preselection in complete view
Re: Temporarily disable preselection in complete view
from pivy import coin
view=Gui.ActiveDocument.ActiveView.getViewer()
root=view.getSceneGraph()
root.highlightMode.getValue()
root.highlightMode.setValue(2) # off
Thank you wmayer,
is exactly what I was looking for!
BR,
HoWil
BR,
HoWil
Is it possible to do that with the selection filter ? If so what is the string to use ?wmayer wrote: ↑Sun Jan 08, 2017 11:57 amCode: Select all
from pivy import coin view=Gui.ActiveDocument.ActiveView.getViewer() root=view.getSceneGraph() root.highlightMode.getValue() root.highlightMode.setValue(2) # off
filter = Gui.Selection.Filter('SELECT None')
Gui.Selection.addSelectionGate(filter)
Gui.Selection.removeSelectionGate()
Support me on Patreon: https://www.patreon.com/FreeCadDevDiary
FreeCad Dev Diary channel:[/b] https://www.youtube.com/channel/UCGMTmJ ... NiPSSEhBHA
You can do thisIs it possible to do that with the selection filter ? If so what is the string to use ?
Gui.Selection.addSelectionGate('SELECT None')
Alternatively, how do you cancel the inactivation as per your code snippet?
root.highlightMode.setValue(0)
