SpecularColor for Faces (Materials per Face)
is there a way to add some material properties to Faces instead to the all Shape?
I would like to have for example a Cube with one Face Gold and one other Emerald?
I know it is possible to assign per Face Transparency, so I was thinking of something similar...
That would allow to load i.e. a colored model (union of colored parts) and display it with shininess as for example is possible in CADAssistant
Thx
Maurice
Thx
Maurice
Re: SpecularColor for Faces (Materials per Face)
hi
may be in comboview click right to shape and "Set colors..."
python code:
see here [Résolu] Couleur différentes sur les faces
mario
python code:
Gui.ActiveDocument.Box.DiffuseColor=[(1.,0.,0.),(0.,1.,0.),(0.,0.,1.),(1.,1.,0.),(1.,0.,1.),(0.,1.,1.)]
mario
Hi @mario52mario52 wrote:hi
mario
thanks for going into this...
unfortunately what you are linking is just Diffuse color per Faces...
what I would need is Materials for Faces...
ATM I think Materials can only be added to all Shape and not to singular Face
Please have a look at the two situations:
1) Cube, Cone, Sphere with Materials added (right click 'Appearance')
2) the same objects fused as one where only Diffuse property is maintained... This is only an aesthetic feature, but, I see that something in going into 'UX/UI Design' and user experience
I just noticed that main CADs just have shininess and Specular effect enabled by default (i.e. Catia, SolidWorks, CADAssistance by OCC) I tried by python code but it seems there ares no other properties than Diffuse for Faces
Maurice
- microelly2
You have to hack the pivy node.
would you please give me some tips? or a simple example?microelly2 wrote:You have to hack the pivy node.
that would be great!
Maurice
- microelly2
v=App.ActiveDocument.ActiveObject.ViewObject
v.ShapeMaterial
m=v.ShapeMaterial
m.EmissiveColor=(1.0,0.0,0.0,0.5)
m.SpecularColor=(0.0,1.0,0.0,1.0)
m.EmissiveColor=(0.0,0.0,0.0,0.5)
m.DiffuseColor=(0.0,1.0,0.0,1.0)
m.SpecularColor=(1.0,1.0,0.0,1.0)
Hi @microelly2microelly2 wrote:Code: Select all
v=App.ActiveDocument.ActiveObject.ViewObject v.ShapeMaterial m=v.ShapeMaterial m.EmissiveColor=(1.0,0.0,0.0,0.5) m.SpecularColor=(0.0,1.0,0.0,1.0) m.EmissiveColor=(0.0,0.0,0.0,0.5) m.DiffuseColor=(0.0,1.0,0.0,1.0) m.SpecularColor=(1.0,1.0,0.0,1.0) m.EmissiveColor=(1.0,0.0,0.0,0.5)
whith that I can associate a diffuse color and a specular color to an object...
what I would need is to assign diffuse and specular per faces... is that possible?
I mean I would need to create a material to be attached to a face
for example if the face has red diffuse color, I would need to attach an orange specular color; if the face has blue color, I would need to attach a lightblue color
thx again for support
- microelly2
this can be very complex,
the simplest way ist to generate faceholders for your faces and colorate each this way
I did this with transparency here:
freecadbuch.de/doku.php?id=blog:transparenz_-_peel_the_egg
- microelly2
An other way is to change the inventor node
I have done this with texture images here
https://freecadbuch.de/doku.php?id=blog ... en_bringen
the structure of a per face coloring you find at the end of this link
http://developer90.openinventor.com/con ... ile-format
https://webdocs.cs.ualberta.ca/~graphic ... mentor.pdf
pages 137,282 ff
pages 137,282 ff
Hi @ microelly2microelly2 wrote:this can be very complex,
the faceholder way is quite complex and will change the model to reach its visualization... so I wouldn't like to consider it...
that seems the right / feasible approach!microelly2 wrote:An other way is to change the inventor node
I have done this with texture images here ...
I will have a look at the docs...
thx
M
