How can i build thousands of objects, which differ only in one parameter?
For example, a certain parameter has the initial value 1 and this value should increase in the next object by 0.001 until the value is 2. In this case you get 1000 objects.
In addition, how can i export all these objects into 1000 different obj-files, without clicking on every object?
thousands of parts, which differ only in one parameter
- DeepSOIC
Re: thousands of parts, which differ only in one parameter
Lattice ParaSeries is just for that! Please note that it's prone to crashing FreeCAD on linux. On windows it behaves better (win. FreeCAD is able to catch and absorb access violations)
- DeepSOIC
But for that you'll probably have to make a console snippet.Chao_Tyc wrote:In addition, how can i export all these objects into 1000 different obj-files, without clicking on every object?
Do you want to export each object into an independent file, or all objects into one file? if latter, you just export the paraseries object.
