Is it possible to change an Icon of a Combo view object?
easyw-fc
Post by easyw-fc »
is it possible to change an icon of a combo view object with python code?
DeepSOIC
Re: Is it possible to change an Icon of a Combo view object?
Post by DeepSOIC »
Yes. Reimplement getIcon method of viewprovider:
class ViewProviderSomething:
    def getIcon(self):
        return ":/icons/PartDesign_Body_Tree.svg"
Chris_G
Post by Chris_G »
I did a little bit of experiment with the icon recently here : Mirror Layer
The very first function of the macro, createIcon(color, override, mirror), returns a svg string, with custom color and aspect :
The getIcon() function, near the end of the macro, returns an icon from the svg string ( self.icon ) using a temp file ( found the trick on this forum ).
Unfortunately, I have not found a way to ask for icon update, from within the FeaturePython object ...
So the Icon update needs a hide / show of the object with spacebar.
Customizable icons, that would be a cool feature ...
