I like the sound of that.emills2 wrote:...i have a special non-bezier grid and surface just for that task.
tutorials for my NURBS macros
Re: tutorials for my NURBS macros
i just tried it out, you are correcttriplus wrote:Yes this is similar to the version i used. If you will try the latest one (Version: 0.17.10101):
https://github.com/FreeCAD/FreeCAD/releases
You will likely observe the same issue as mentioned earlier. Note that i didn't check the code and i don't know if anything changed in FreeCAD. If it's tolerance related something like this should fix it (in pseudocode):
i can open my files in 0.17.10101 but any edit that recomputes the grid fails in the 'orient_a_to_b' routine (as Microelly correctly determined)
i'm fine with adding tolerance checks in principle, but i don't know if i can keep up with the release schedule. And the icons would look different all the time, the tutorial pictures would never match...this is a big deal.
So i can't write for 0.17, but the system is basically useless without sketch attchment in 0.16
I wish an official .17 would get released so i could write my tools against that i might have to host a particular binary that works with my tools. But even that is extra work, and it will turn people away. I'm really big on the principle that 'it has to actually work'.
you are right, and i do use a similar mechanism in many spots. However, it was really nice to not need it in cases where the points are identically equal.triplus wrote:emills2 wrote: You will likely observe the same issue as mentioned earlier. Note that i didn't check the code and i don't know if anything changed in FreeCAD. If it's tolerance related something like this should fix it (in pseudocode):
if abs(p1 - p2) < 1e-07: points equal else: points not equal
I need to apologize for all the whining sorry!emills2 wrote:I wish an official .17 would get released so i could write my tools against that i might have to host a particular binary that works with my tools. But even that is extra work, and it will turn people away. I'm really big on the principle that 'it has to actually work'.
I know the solution, and no one owes it to me! i just need to learn to compile FreeCAD, then i can maintain my own version exactly how i like it.
Until then, i am thankful for whichever binaries others prepare for me.
i have fixed the issue that affects this tutorial on 0.17.10133, so it should be functional. The other issues i mentioned don't come up as far as the tutorial 0.01 and 0.02 are concerned.
turns out it was just the tolerance...over...and over...and over. With different error messages each time, and sometime no error messages, just a subtly broken model, that appears to work. But it's fixed!
There you have it. Being tolerant is not always easy but it can prove to be useful!
As i was committing new stuff today, i realized today that i had not uploaded the fix i did 9 days ago to the problems reported by Triplus and Microelly2 sorry!
Everything is tested up to 0.17.10291 (and 0.17.10131)
Tutorial 0.03 Point_onCurve ControlPoly4_Segment ControlPoly6 and CubicCurve6 on the way. model and images ready. I hope to have it ready this weekend.
shown below: G2 blend of a line segment to a true circular arc. Shown as generated by default. There are many degrees of freedom remaining that are available for design purposes or for manual tuning towards G3 Once again, if anyone tries this and finds it broken, please let me know!
Was the last post in this thread edited?
As i don't remember:
Reading this. And i was waiting for the thread to be bumped again. But as it didn't happen i decided to ask today on the current status of things. And as for the Tutorial 0.03 itself it wasn't published yet?emills2 wrote:Tutorial 0.03 Point_onCurve ControlPoly4_Segment ControlPoly6 and CubicCurve6 on the way. model and images ready. I hope to have it ready this weekend.
If a post is edited after someone has read it, it shows the time and number of edits at the bottom. I know this because I had to correct at least typos in my posts more than once, although I always preview them. (Example: https://forum.freecadweb.org/viewtopic. ... 69#p171527)triplus wrote:Was the last post in this thread edited?
