tutorials for my NURBS macros
emills2
Re: tutorials for my NURBS macros
Post by emills2 »
Im just guessing here until i can see your file.
For the 'mode undefined' error. I believe this can only happen if you do not have 4 objects selected. Or 3 but ignore that for now.
For the 'curves do not share endpoints' error. Not only must the endpoints be correctly linked at the sketch level, the polys must be selected in the order they form a loop in! Front right back left, not front back left right. In the first case, the second object picked touches the first object. The third touches the second. The fourth touches the third (and the first). In the second example, front doesnt touch back at all. These two cannot be selected in a row.
Why not sort it all out in the macro? Then there would ne no way to say which side is in or out normal wise. It is critical later on.
This is what the specific instructions at step 25 try to enforce.
This is just a guess until i can run a test. You may well be right that the problem is on my side. :)
triplus
Post by triplus »
Hi @emills2.
Don't worry about it a bit and take your time. I don't plan to do any more tests today. And it could end up i just need to do something differently. As for the file sure no problem.
ControlGrid44 and CubicSurface44 bare bones.FCStd
(21.73 KiB) Downloaded 45 times
emills2
Post by emills2 »
Thanks. Now i know what i'm doing after work :D
emills2
Post by emills2 »
annoying news. your file works fine on my computer :( the bad part is that makes it very hard for me to debug. please try opening the model attached here on your machine and lets see what it does. If the grid shows up we will be in good shape.
i selected the polys exactly in the order you created them, which is correct (you followed the tutorial perfectly). and bam!
Triplus tutorial 0.02 ControlGrid44 problem 01.PNG (150.81 KiB) Viewed 1618 times
in the created object, under the data tab, you can see the exact order they were fed in.
Triplus tutorial 0.02 ControlGrid44 problem 02.PNG (56.08 KiB) Viewed 1618 times
Could you please try it again, but pick the polys from the model tree, not the 3d window?
Here's what can happen if you pick in the window:
if you pick the same one twice in a row, on a different line within the poly, it only registers as one selection object, so you would have 3 objects in the selection, one of which has 2 sub-selections. because the top level of the selection has 3 objects, this would trigger the triangle mode. Since the triangle isn't closed, you then get the 'curves do not share endpoints' error.
In this library, i do a lot of work to completely bypass the topological naming issues in FreeCAD, 90% of the code is handling input, reversing curves, flipping grids as necessary. I have left the absolute bare minimum as rules to follow from the user:
-sketch lines must connect correctly within a sketch
-sketch to sketch connections must be exact
-curves/polys must be picked in the order they actually connect in to form a loop. this is necessary to define inside/outside of surfaces. if you pick counter-clockwise, the surface points towards you.
this last rule is what step 25 in tutorial 0.02 is all about: pick front, right, back, left.
The problem with all of this is that it is tremendously boring, and i was really hoping not to have to talk about it so early in the tutorials. Pretty gumball surfaces are the fun side, topological sketching is the boring price!
I may need to do a premade 4 poly model just to have people focus on picking the polys in the right order. I gambled and decided to focus on the sketches the first time around.
Thank you for putting in all the effort!
@Microelly2 i like gifs too!
transition to 0.17 03 - 00.gif (267.84 KiB) Viewed 1618 times
But sometimes, they just make things more mysterious than before :lol:
ControlGrid44 and CubicSurface44 bare bones - added Grid.FCStd
(31.61 KiB) Downloaded 34 times
triplus
Post by triplus »
I was able to complete the second tutorial on FreeCAD 0.17 (but a few hundred commits older version). Do you use the latest FreeCAD 0.17? In this older version on page 7 of the tutorial. Moving the arc sketch (at Z: -200) similar issue:
  File "NURBSlib_EVM.py", line 1553, in execute
    if quad34[0]!=poles3[0] and quad34[0]==poles3[-1]:
<type 'exceptions.TypeError'>: 'int' object has no attribute '__getitem__'
After re-attaching the Sketch as instructed in the tutorial everything was fine. I haven't check in the code and if you won't be able to confirm this when using latest FreeCAD 0.17. Could this be tolerance related issue? When you compare for equal points do you use tolerance?
P.S. Anyway i never had such control over surface in FreeCAD yet and i like this new experience. Waiting for the Tutorial_0.03.
emills2
Post by emills2 »
triplus wrote:Do you use the latest FreeCAD 0.17?
This is my FreeCAD
Version: 0.17.9528 (Git)
Hash: 4efd3e894a9d3c1954603c60c411d434506d44e7
Python version: 2.7.8
OCC version: 7.0.0
I don't have a linux machine right now, and i don't dual boot (i used to set it up, and always ended up using one OS exclusively per machine). My reference version is 0.17_pre found at https://github.com/FreeCAD/FreeCAD/releases
If i didn't absolutely depend on DeepSOIC's sketch attachment and references, i would insist on 0.16 as the reference. I will add this info in the tutorial. I want anyone to be able to try this without ever having to compile anything. I personally find it a real barrier. I forced myself to compile a few things, thinking that getting it done would give me a sense of victory and accomplishment. It never did. i just ended up feeling i had lost a lot of time and couldn't really tell how many things i'd broken by shoving libraries around :D .
triplus wrote:I haven't check in the code and if you won't be able to confirm this when using latest FreeCAD 0.17. Could this be tolerance related issue? When you compare for equal points do you use tolerance?
So far, i have been able to use FreeCAD mechanisms where everything stays exact and falls below the tolerance threshold of every function i use (with no special effort on my part). That is true so far for everything in Part, and whichever portion handles == for vectors (probably Base?)
But i'm not sure that's even an issue here!
triplus wrote:Moving the arc sketch (at Z: -200) similar issue:
CODE: SELECT ALL
That is what is supposed to happen! the goal of this section of the tutorial is to show how to fix a weak part of the model made in a hurry. The poly endpoints were linked through a sketch reference instead of an attachment, and this breaks when we move one sketch plane but not the other.
The model in the 3D window and the broken object icons in the model tree give just enough information that you don't even need to look at the error messages in the report view. The tutorial then shows how to repair it
microelly2
Post by microelly2 »
CODE: SELECT ALL
Easier to understand
def orient_a_to_b(polesa,polesb):
	else:
		print 'curves do not share endpoints'
                raise Exception('curves do not share endpoints')
                # or
                return []
instead of
return 0
emills2
Post by emills2 »
triplus wrote: P.S. Anyway i never had such control over surface in FreeCAD yet and i like this new experience. Waiting for the Tutorial_0.03.
i have to do 4 hours of actual code before i'm allowed to do the next tutorial!
You can start building 'quilts' of CubicSurface44s like the pink ones below. edge polys must be shared between grids :use the SAME poly in multiple grids, don't copy paste and reuse. polys must touch at the end, etc. use attachment not sketch link unless you are 100% sure the planes will never move.
triple66triangle 03 - 01.png (231.73 KiB) Viewed 1572 times
don't even try to make it too smooth at the seams, just 'sketch in' the major charateristic surfaces of the model. Cubic bezier cannot be smoothed really well at the seam, i have a special non-bezier grid and surface just for that task.
the next set of tutorials will deal with picking point along the edge curves, create grids for subsections, blend two grids that share an edge...like so
triple66triangle 03 - 02.png (277.87 KiB) Viewed 1572 times
emills2
Post by emills2 »
microelly2 wrote:
CODE: SELECT ALL
	else:
                # or
                return []
instead of
return 0
I take your word for it, i only know as much about programming as i absolutely need to get the task at hand done. my error reporting techniques are not very consistent. most of the time i print intermediate steps to the console until it works, then i comment out the prints.
There are multiple things going on here that are not clear yet to me.
are we talking about:
-the polygon loop being picked in the wrong order?
-failures in the macro itself?
-failures in the functions called by the macro?
i have no way of testing beyond
OCC version: 7.0.0
I will look into raising exceptions. it does sound better.
triplus
Post by triplus »
emills2 wrote:You can start building 'quilts' of CubicSurface44s like the pink ones below.
No that ain't going to cut it. I'll wait. ;)
Yes this is similar to the version i used. If you will try the latest one (Version: 0.17.10101):
You will likely observe the same issue as mentioned earlier. Note that i didn't check the code and i don't know if anything changed in FreeCAD. If it's tolerance related something like this should fix it (in pseudocode):
if abs(p1 - p2) < 1e-07:
    points equal
else:
    points not equal
P.S. Take your time no hurry whatsoever.
