How to create a clone object with a desired name?
ChapaikinVA
Post by ChapaikinVA »
It's a very simple question from a beginner.
How to create a clone object with a desired name? I mean a name that can be used in form:
FreeCAD.ActiveDocument.<a clone's name>
Give a script example, pls.
Дедушка Мороз, (если ты есть) пусть в новом году FreeCAD не будет таким глюкодромом. Хотя бы для Part / PartDesign! Ну хотя бы чтобы булеаны не глючили! Кроме как на тебя надеяться, видимо, больше не на кого ... :cry:
mario52
Re: How to create a clone object with a desired name?
Post by mario52 »
hi
import Draft
sel = FreeCADGui.Selection.getSelection() 	# select object
obj = Draft.clone(sel[0])				# create a clone selected object
obj.Label = "tyty"					# give a Label
#Data
print App.activeDocument().getObjectsByLabel("tyty")[0].Scale					# search by label (Data)
#View
print App.activeDocument().getObjectsByLabel("tyty")[0].ViewObject.Visibility		# search by label (View)
see How to recognize Draft Clone objects?
mario
ChapaikinVA
I need to choose a Name not Label for a clone. It is easy when create an object by addObject method. But I don't know how to choose name (not label) for a clone.
yorik
Founder
Post by yorik »
There is no way to do that at once, but you can simply mimmick the code inside Draft.clone (src/Mod/Draft/Draft.py line 2827), and first create the object yourself then apply _Clone to it.
