Part-o-magic [New: Selection tools, container duplication]
- DeepSOIC
Re: Part-o-magic (again)
New Features!
+ PartDesign Additive shape container
+ PartDesign Subtractive shape container
They are somewhat similar to PartDesign Booleans, but I think they are a bit more useful. Here's an example of why you might need them.
Let's say you are modeling a flange, with a non-circular opening. Lets use a slot. We want screw holes around the opening... There is no PartDesign pattern (AFAIR) that can produce the necessary holes, but there is a handy tool in Draft workbench that can help, Draft PathArray. This is where PoM Subtractive Shape comes in.
* Create Subtractive shape container. You will be presented with an empty screen, where you should model the shape that cuts the holes.
* Add shapebinder of the sketch that was padded (select Sketch in tree, and click PoM Shapebinder).
* From Sketcher workbench, create a new sketch, and constrain up a slot that goes through the centers of future screwholes.
* From Part workbench, add a cylinder, and set it up to have the right radius, and enough height to penetrate all the way through. Leave it at the origin
* Select Cylinder, Sketch001, and apply Draft PathArray * Done! Leave the container to get back into Body (e.g. use PoM Leave command, or double-click Body in tree).
You may need to click Recompute button to see the result. Also, there is a chance Tip property of SubtractiveShape isn't pointing to the actual shape to use for cutting (PathArray). In that case, you can fix it by using PoM Set as Tip command.
If it would be only about Part Container i could give you a simple answer. But i feel there will be (much) more to it. Therefore i guess lets wait and see what the future brings.DeepSOIC wrote:Upstream meaning merge into master FreeCAD? Maybe, but only when automatic sorting of new objects into active group is implemented. What workbench should they land to? Assembly? or spread over various containers across workbenches?
As for feature hierarchy, I don't know why does it behave like it does (flattens out everything). In C++ version of Module, I didn't have that problem. I think fixing it is most likely a C++ work.
Nice additions. As for placing such features in current PartDesign NEXT workflow. Ouch!New Features!
Didn't test it yet, but that's exactly what I was looking for!!DeepSOIC wrote:New Features!
Thanks a lot!!
Re: Part-o-magic (again) [new features: PartDesign add/sub shape containers]
Interesting idea. It is really nice to see for what those extension can be used! I wonder if we should change the boolean op in PartDesign to be a container. It would be like your new objects with the only difference that one can choose Add/Sub/Common. May be moreusefull than it is now.
- DeepSOIC
Yea, extensions are great, thanks for making them happen! Now I can knock out a container almost for anything in no time at all , and even make it attachable (possibly, I haven't tried yet).ickby wrote:It is really nice to see for what those extension can be used!
+10ickby wrote:Interesting idea. It is really nice to see for what those extension can be used! I wonder if we should change the boolean op in PartDesign to be a container. It would be like your new objects with the only difference that one can choose Add/Sub/Common. May be moreusefull than it is now.
- DeepSOIC
New feature!
* Exporter
It is an object you add to the project, and it can automatically export an object into a file whenever it changes. It can export Parts and Groups, but limited to a single level nesting (child Part containers are fed to FreeCAD's exporter, but FC's exporters usually ignore them).
I hope that this picture explains well what it does. Exporter checks that model has no features in an error state, will refuse to export if it finds errors.
BLUE = edits
* Exporter
BLUE = edits
Re: Part-o-magic (again) [new feature: Exporter]
This is really nifty, DeepSOICDeepSOIC wrote:New feature!
- DeepSOIC
Well, it looks like I just did it to some extent, almost by accidentDeepSOIC wrote:4) I'm afraid I won't be able to do iteasyw-fc wrote:4) ability to select an App::Part root node and export the assembled/children components as STEP
Great! I see it preserves colors tooDeepSOIC wrote:Well, it looks like I just did it to some extent, almost by accident
Better day by day!
