Macro for opaque and transparent mode
rebeldevil
Post by rebeldevil »
Hello everyone!
I'm new to this forum and I would like start my participation expressing my gratitude to the FreeCAD developers for they wonderful work and results reached as for the date of this post.
I would also like to start participating providing two little but for me useful macros which allows to switch all the objects within a project from opaque to a given transparency value:
To make all solids translucent I've used the following code:
doc = Gui.activeDocument()
objs = FreeCAD.ActiveDocument.Objects
for obj in objs:
	if obj:
		o = doc.getObject(obj.Name)
		if hasattr(o, 'Transparency'):
			o.Transparency = 50
and to make them again opaque you simply need to change the last line giving a value of 0.
I've found that code useful in conjuction with a custom toolbar created within the preferences and/or with keyboard shortcuts.
Any comment or correction on the code is welcome as I'm not really familiar with Python and its API's.
mario52
Re: Macro for opaque and transparent mode
Post by mario52 »
hi welcome
# -*- coding: utf-8 -*-
for obj in objs:
#   if obj:
#      o = doc.getObject(obj.Name)
#      if hasattr(o, 'Transparency'):
      obj.ViewObject.Transparency = 90
other example macro for transparency toggle 0 to 70%?
mario
rebeldevil
Thank you mario52. Searching within the forum didn't return topics related to the macro I was searching for so I've wrote it myself.
Anyway your suggestion are very instructive.
