SheetMetal WB migration to 0.17
shaise
Re: SheetMetal WB migration to 0.17
Post by shaise »
DeepSOIC wrote:Warning: forced update!
I think I messed something (not that familiar with git) I made a git pull and got many conflicts.
After compilation nothing works now anymore... :? I get
 "Gui::Document::slotNewObject() no view provider for the object PartDesignGui::ViewProviderPython found"
and some other errors.
will try a clean clone now. but it will take time.
DeepSOIC
Post by DeepSOIC »
shaise wrote:I think I messed something (not that familiar with git) I made a git pull and got many conflicts.
Actually, I'm not familiar with git pull :lol:
When I clone someone-else's branch of FreeCAD, I do something like this:
git remote add DeepSOIC https://github.com/DeepSOIC/FreeCAD-ellipse.git
git fetch DeepSOIC
git checkout DeepSOIC/PartDesignPy
shaise
Post by shaise »
Hi DeepSOIC,
I too use that for clean cloning, I just wanted to save some time...
Anyway, I think the "bad" build actually is OK, and here is what I found so far:
When you create a Part:FeaturePython, it is assigned a default provider (to .VeiwObject), and has a 'Proxy' attr that gets the Python ViewProvider class.
If you do the same for PartDesign:FeaturePython the ViewObject is Null. Hence no proxy to set. Perhaps I should do it differently?
Clean build on the way. Just in case....
shai
DeepSOIC
Post by DeepSOIC »
shaise wrote:If you do the same for PartDesign:FeaturePython the ViewObject is Null. Hence no proxy to set. Perhaps I should do it differently?
No, it should work exactly the same.
>>> App.ActiveDocument.addObject("PartDesign::FeaturePython")
<PartDesign::Feature>
>>> App.ActiveDocument.ActiveObject.ViewObject
<PartDesign::ViewProvider>  #<-- certainly not None/Null
shaise
Post by shaise »
OK.
Waiting for clean build.
Will report when finished
shaise
Post by shaise »
DeepSOIC wrote:it should work exactly the same.
Yes!!!!!! :D
Everything seems to work perfectly now!
Thanks a lot for all you support.
For anyone who wants to test, please download Branch V0.17 from https://github.com/shaise/FreeCAD_SheetMetal/tree/V0.17
It should work both inside and outside PartDesign. It is also backward compatible with freecad 0.16.
As soon as the next v0.17 pre build including DeepSOIC's changes will go out, I will merge it to master.
shai
sgrogan
Post by sgrogan »
shaise wrote:As soon as the next v0.17 pre build including DeepSOIC's changes will go out, I will merge it to master.
OSX/Win builds are published: https://github.com/FreeCAD/FreeCAD/rele ... g/0.17_pre
Ubuntu is building: https://code.launchpad.net/~freecad-mai ... ners-daily
"fight the good fight"
shaise
Post by shaise »
Thanks sgrogan!
SheetMetal fixes merged to master.
Tested it using the Addon Manager, Works great with PartDesign WB, and follows its workflow.
NormandC
Post by NormandC »
Awesome Shai! :D
Thank you DeepSOIC for adding this functionality, and congrats Shai for being the very first module developer to use it! :)
I'm eager to test the new 0.17-compliant SheetMetal but I need to restrain myself, I've got some stuff to take care of first and it will never happen if I continue sticking around the forum... :oops:
easyw-fc
Post by easyw-fc »
shaise wrote: SheetMetal fixes merged to master.
Thx Shai ... this has been fixed quickly!
and Thx Sgrogan as always for your builds
Maurice
