I have a point P(x,y,z).
I would like to get its coordinates expressed into another orthonormal coordinate system (a_point,v1,v2,v3)
Are there any buit-in functions for going back and forth between 2 coordinate systems ?
Thanks,
Chris
Convert between 2 coordinate systems
- DeepSOIC
Re: Convert between 2 coordinate systems
Yes, Placement defines a coordinate system, and supports converting points to/from.
The only thing that seems to be missing is a constructor for placement that takes axis vectors as input. For that, in Lattice, I wrote up a routine. Feel free to reuse it.
def makeOrientationFromLocalAxes(ZAx, XAx = None):
makeOrientationFromLocalAxes(ZAx, XAx): constructs App.Rotation to get into
alignment with given local Z and X axes. Z axis is followed strictly; X axis
is a guide and can be not strictly perpendicular to Z axis; it will be
corrected and modified
if XAx is None:
XAx = App.Vector(0,0,1) #Why Z? Because I prefer local X axis to be aligned so that local XZ plane is parallel to global Z axis.
#First, compute all three axes.
ZAx.normalize() #just to be sure; it's important to have the matrix normalized
YAx = ZAx.cross(XAx) # construct Y axis
ParaConfusion = 1e-9
if YAx.Length < ParaConfusion*10.0:
#failed, try some other X axis direction hint
#failed again. Now, we can tell, that local Z axis is along global
# Z axis
XAx = App.Vector(1,0,0)
YAx.normalize()
XAx = YAx.cross(ZAx) # force X perpendicular
#hacky way of constucting rotation to a local coordinate system:
# make matrix,
m = App.Matrix()
m.A = list(XAx)+[0.0]+list(YAx)+[0.0]+list(ZAx)+[0.0]+[0.0]*3+[1.0]
m.transpose() # local axes vectors are columns of matrix, but we put them in as rwos, because it is convenient, and then transpose it.
# make placement out of matrix,
tmpplm = App.Placement(m)
# and extract rotation from placement.
ori = tmpplm.Rotation
return ori
def makeOrientationFromLocalAxesUni(priorityString, XAx = None, YAx = None, ZAx = None):
constructs App.Rotation to get into alignment with given local axes.
Priority string is a string like "ZXY", which defines how axes are made
perpendicular. For example, "ZXY" means that Z is followed strictly, X is
made to be perpendicular to Z, and Y is completely ignored (a new one will
be computed from X and Z). The strict axis must be specified, all other are
optional.
# see Lattice (lattice2GeomUtils.py) for actual code, it's quite long
- DeepSOIC
You can also use App.Matrix if you are dealing with left-handed coordinate systems (these are not covered by placements)
Thanks DeepSOIC,
I'll have a look at that and hope I will understand
